e30 s50 swapped
  • atldohc
    • Nov 2008
    • 359
    well owenjm youve probably already found a solution to your problem, but for anybody with this same situation i installed an e36 325i slave cylinder yesterday. and the pedal is indeed stiffer and engages at a stocklike pedal height. the pushrod appeared to be a little longer than the m3 zf slave cylinder, which seems to work out perfect for use with the stock clutch master. :grin:
