Wiring help please..
  • e30this
    • 3580
    Ok So here is the deal. I want to wire my M20 engine side plug directly to my M50 harness. My car is a 90 325is with air bag and abs, but both have been removed.
    All I know about the M50 harness is that it came from an automatic vanos E36 M50.
    Me and Unearth078 have searched for the past hour for info on wiring this up but when we find wiring info half the wires dont match my C101 plug.
    So here is a list of my wire and the pin numbers. The only thing I cant figure out is where the two Brown W/Grey stripe wires go because the C101 was cut off when I got the harness.
    So if someone would be kind enough to put the numbers next to the pins of where I need to plug them into my M20 engine side plug that would be amazing. :-D
  • e30this
    • 3580
    Ok, So I found a chart with what pins go where. But the colors on that chart dont match the colors that I have. Can someone please double check it?? I will add to the chart if I find any more info on the colors that are not listed. I dont feen safe wiring shit up if the colors on the charts I found dont match.
    • gregslow318i
      • Sep 2007
      • 1918
      pin #3 on the x20 is not used
      pin 23 on the x20 is for the oil psi switch it go to pin 5 on the c101
      oh ps pm me if you need a harness adapter
      btw e30=c101 e36=x20
      looking for a e30m50 swap harness adapter pm me $150 shipped
      email nitroman12@gmail.com
      • e30this
        • 3580
        Ah, So I pretty much got it right other then the colors on the E36 harness not matching with the E36 chart I found.
        I dont need an adapter. Im going to the dealer today to order a C101 plug to splice onto my harness. They are like 16.00 and .80 for each pin.
        Thanks for the offer though.
        • e30this
          • 3580
          PLEASE!! I wanna get this done ASAP...
          • Uber E30
            • 1409
            IIRC the harness/pins werent the expensive part, there is a special bmw only tool that is used to mate the pins/wires.
            -Alex
            • Uber E30
              • 1409
              Ah yes, here is what i was thinking about:
              Originally posted by matt
              NO. That's not the point here at all. Treehouse Racing has great products and tech support by all accounts. (I have a set of their CABs) And it's not their fault you'd rather not pay what they ask for their services. I was || this close to ordering a wiring adapter from them, but doing Ben's has convinced me that I can do it myself cleaner and better, with the connections I have.
              Out of respect for them, you guys are on your own for part numbers. But I will tell you that the tool set to get the pins out of the connectors is $867.50 and the tool set to crimp and install the pins onto the wires is $652.50.
              Matt
              Its in reference to this thread
              -Alex
              • JGood
                • Jan 2004
                • 7959
                The only reliable way to do your pinouts is to use the ETK.
                It has colors, pins, where the wire is from and where it is going, and if it's ground/power/switched power/signal/etc...
                I did it that way and posted my results here. Everyone said it looks good. Wired it up, and it was wrong. I messed up on one of the wires and nobody caught it.
                Don't trust anybody else, do it yourself and triple check it.
                I had an 87 325is that I put an 89 engine into. Everyone here said it will just connect right up, the c101's are the same. The harness melted, because it does NOT connect right up. Everyone said the x20's are the same too. I don't trust that either, obviously...
                e30 restoration and V8 swap
                24 Hours of Lemons e30 build
                • e30this
                  • 3580
                  I looked through that link ^^^ I will have to print stuff out. I hate running back and forth between the comp and wiring harness. I just need to find someone with a printer.
                  I just removed all of my automatic wiring harness last night. People made it seem harder then what it was.
                  • jogfrogjog
                    • May 2007
                    • 46
                    I did mine... it's not so bad... check some of the articles... akg has a wiring diagram on there... at least it might help... also, the e36 harnesses are slightly different depending on the options on the car...
                    http://www.akgmotorsport.com/usm50swap.html
                    at least it's a starting point, don't take it for 100%, some of it was not correct... I'll see if I can find my charts... check some of the threads I have asking about wiring on the tech, you'll find the stuff for the m50 and early style e30.
                    • White325is
                      • Oct 2006
                      • 5947
                      Originally posted by e30this
                      Ok, I bought an M20 c101 plug from the dealer. Im trying to figure out what e36 pins go into what E30 pin holes.
                      The car is an 87 325.
                      • apexhead
                        • 32
                        Have you figured this out yet? I see a few problems with your chart. Rpm and road speed are mixed up and pin 18 should be hooked up to pin 18.
                        • White325is
                          • Oct 2006
                          • 5947
                          ok I added the 18 to where its suppose to go if you say..
                          What other numbers I have mixed?
                          • JGood
                            • Jan 2004
                            • 7959
                            haha dude you're gonna light something on fire just randomly switching wires from what various people say. He's right, but you really need to look at the schematics. It's the only way to do this. It tells you EVERYTHING you need to know and then some. Wire color, connector, pin # on the connector, body side use, engine side use, whether its ground, power, switched power, signal, etc....
                            Just go through and make a complete chart for the c101 and x20, then it's simply just matching up the wires based one use. It shouldn't take more then a few hours.
                            I'm telling you, I went off of info on this forum for an m20 swap, and I melted a harness. Went off of info on this forum for an m50 swap, and the car wouldn't start. Both times everyone told me that the wiring was right. Well, wrong. Half the charts floating around on this forum that you see when you search for wiring info are wrong.
                            • TurboFox93
                              • 173
                              So is there no such thing as a "universal harness" for these swaps. I get the impression that there are so many harness variables that the only way to do it properly is pin out your own harness for you model and year.
