Regulator next to feul pump
  • Mohammed_A
    • 344
    Was changing the pipes at the feul pump under the car and noticed something that looks like a regulator, is this necessary or can i remove it, what does it do?
  • FredK
    • 14764
    That is probably the fuel pulse dampener, which is placed inline between the filter and the injector rail. I guess its purpose was to avoid a resonance in fuel supply when the fuel pump pulse matched up with the pulse rate of the injectors. Most people delete this with no real effect on performance. Some people have noticed a leaning in AFRs with it removed.
    • Mohammed_A
      • 344
      Thanks
      So its got nothing to do with pressure then, reason im asking is coz i have and adj FPR with gauge and when i removed the thing my Fuel pressure shot up from 4 to 6 bars....
