3.0 m50tu
  • Bmwmotorm52
    • 145
    3.0 m50tu
    I got my hand on a M54 from a 2003 X5.Iwant to know it it is possible to use the M54 crank & rods in my m50 block with my m50 head and stock pistons.About wat cr and power would i make?
    sigpic:):)
  • hoveringuy
    • Dec 2005
    • 2722
    I would use the M54 crank and rods in the M54 block and use the M54 head.
    • zav3n
      Curious George!
      • Mar 2007
      • 223
      m54 crank = s52 crank
      • Bmwmotorm52
        • 145
        iam tryin to make more power with my stock m50..i was think i can make a 3.0 out of it? ..
        sigpic:):)
        • Bmwmotorm52
          • 145
          I want to know would it work?
          sigpic:):)
          • lifeiskaos
            • 1709
            it would work fine, but with a stock m50 headgasket your compression will be significantly lower than stock. you'll want to look into thin (cometic) headgaskets or custom pistons. with the thinner headgasket, you might want to check valve clearance with the pistons.
            • balooshinakus
              • 511
              Heh, somehow I had a feeling you would say that.
              • hoveringuy
                • Dec 2005
                • 2722
                Well, he says he has the entire M54 out of an X5 and only wants to use the crank to build a 3.0 out of an M50??
                • lennon
                  • Jun 2008
                  • 1416
                  no doubt. if you have the whole m54, youd be silly to just use it's crank.
