M50 swap procedure - essential checklist
  • hi its me alec
    • Apr 2008
    • 478
    Is the red wire coming out near the OBD for engine power? Just re-discovered that mine is cut...
    this guy
    WTB: early e30 sedan front doors
    • jrdeamicis
      • Nov 2008
      • 956
      After reading the check list you are missing a postive dme wire that Is near the pass fender that ties to the fusible link. That should give you fuel and spark.
      Past Car : E30 S50 6 Speed 5 Lug 3.73
      Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
      ___________________________________________
      BNB Designs
      Engine Swaps, Fabrication, Innovation, General Repair
      Richmond CA
      Julian 848-248-8029
      • hi its me alec
        • Apr 2008
        • 478
        Thank you for the confirmation!!
        • jrdeamicis
          • Nov 2008
          • 956
          for sure.
          BNB Designs
          Richmond CA
          Julian 848-248-8029
          • hi its me alec
            • Apr 2008
            • 478
            Still didn't start though.. lol
            • jrdeamicis
              • Nov 2008
              • 956
              Spark or fuel yet?
              BNB Designs
              Richmond CA
              Julian 848-248-8029
              • Jean
                • 18228
                Add to the list:
                Uncut or virgin engine wiring harness :)
                • hi its me alec
                  • Apr 2008
                  • 478
                  Spark or fuel yet?
                  No fuel for sure, will test for spark today after work.. got dark out last night.
                  • travis816
                    • 828
                    no that cut red wire shouldnt matter. you should have the black one from your chassi to the starter. that should be all you need for power
                    88' m3
                    91' 318is
                    • jrdeamicis
                      • Nov 2008
                      • 956
                      Right...
                      The DME runs on sunshine and beanie babies.
                      BNB Designs
                      Richmond CA
                      Julian 848-248-8029
                      • Jean
                        • 18228
                        ROFL.... BMW put that wire there just because.
                        • hi its me alec
                          • Apr 2008
                          • 478
                          Black wire from chassis to starter? I'm running an M20 starter and it seems to be cranking just fine without it. I just have the 2 wires coming from the engine harness
                          • Jean
                            • 18228
                            Wire from battery to starter (sounds like you already have)... ground to the engine. Engine harness + and engine harness ground. Fuel pump / main relays ok?
                            • travis816
                              • 828
                              Its needed on the e36 but not on the e30/m50 swap, you should already have a fuse box positive wire running out of the fuse box. It just needs properly hooked up.
                              88' m3
                              91' 318is
                              • Kerrath
                                • Jun 2008
                                • 577
                                Originally posted by hi its me alec
                                [x] 318 DME grounding plate
                                I've never heard of this before. I assume it's used to ground out the ECU like people say needs to be done. Would you mind telling me more?
