Oil Level Sender
  • whysimon
    • Jan 2007
    • 663
    Oil Level Sender
    What are you guys doing for this. I can't stand seeing the oil light on my check panel.
  • e30s50dan
    • Nov 2008
    • 2076
    black tape;)
    NASA
    BMWCCA member
    PCA member 25yrs
    1991 318IS slick top
    1997 M3 sedan
    2001 325CI DD
    “whoever turns the wheel the least, wins"
    • whysimon
      • Jan 2007
      • 663
      awesome!
      • JGood
        • Jan 2004
        • 7959
        Why not just run a wire to the connector?
        I used an e34 engine/harness which has the sensor and the wiring for it. Since you have the e34 oil pan, and I'm assuming have a sensor in there, why not just wire it up? I'm not sure how it's wired, I'm guessing just a ground and a signal wire to the x20. That would be simple to do.
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
        • etxxz
          • Feb 2006
          • 2085
          get the oil sensor from the e34 oil pan.
          looking at the engine with the sensor's plug looking up. pins left to right are as follows
          left(3) - ground (engine mount ground okay)
          middle(2) - dynamic - pin 10 of your C101
          right(1) - static - pin 2 of your C101.
          you have to check what static and dynamic pins are for eta cars. all "i" cars wire as above and you'll have a working OLS.
          -etxx
          No more e30s for me.
          88 black BMW OBDII 332is dedicated track [sold]
          88 BMW OBDII bronzit 332is [RIP 03/08]
          91 BMW 325i [sold]
          86 Corolla 'Ae86' HB 20v trd [sold]
          http://youtube.com/watch?v=pTj7Hn9v5Rs
          • whysimon
            • Jan 2007
            • 663
            good to know. I'll do that
            • JGood
              • Jan 2004
              • 7959
              It's pin 2 and pin 15 for early cars with a square c101:
              e34:
              LATE e30:
              EARLY e30:
              • whysimon
                • Jan 2007
                • 663
                Thanks very much. Any chance anybody has one?
                • isolatos
                  • Dec 2009
                  • 172
                  this didnt work for me. any other ideas?
                  • BeirBrennerE30
                    • 2740
                    easiest way is to just cut the connector and wire out of the harness when you take your c101 plug. Then just install sensor, run a ground, call it a day.
                    e30sport.net
                    '06 M3 Competition - 6-speed
                    '97 Range Rover Vitesse
                    • isolatos
                      • Dec 2009
                      • 172
                      I wired the plug to my c101 and the light stayed on??
                      • BeirBrennerE30
                        • 2740
                        you have the signal wires backwards... reverse them. or add oil???
                        e30sport.net
                        • dranttna
                          • 127
                          that is good to know. does the dme look at either oil level or pressure, or are they straight to the gauges?
                          325es/24v's/20psi/meth injection/
                          • BeirBrennerE30
                            • 2740
                            oil pressure goes straight to the cluster and the oil level goes stright to the check panel. Nothing else uses them.
                            e30sport.net
                            • isolatos
                              • Dec 2009
                              • 172
                              I will recheck this afternoon. Thanks
