e30 to s50 swap? Clear parts list ?
  • e30loverSC
    • 575
    IM tryin to star pieceing together mey swap parts but im not sure of what all i need? Help i have been searching the forums. I would really like to talk to someone that has done it? I need to know any modifications and how to make it a comfortable driver? HELP
    • 37834
    You need to read the threads in this forum.
    Grover Beach, California
    BimmerHeads.com
    • e30loverSC
      • 575
      have been but its not all there. I need a list..
        • 37834
        I can guarantee you it is.
        BimmerHeads.com
        • White325is
          • Oct 2006
          • 5947
          More then enough is there.
          • JGood
            • Jan 2004
            • 7959
            I JUST spent hours putting together info in a sticky thread at the top of this forum.
            You did not read anything if you are asking the questions you are. I literally spent 6+ months researching. All the info is there. Nobody can put together a comprehensive list for you because there are literally hundreds of variables depending on the parts combination you use.
            But just to prove you wrong, on the very first page of the "comprehensive DOHC engine swap thread", there is a pretty complete list for one particular combination. So actually, all you had to do was open the thread at the top of the forum to get your "list". But like I said, that probably won't even apply to you, unless you use that exact combination of parts.
            e30 restoration and V8 swap
            24 Hours of Lemons e30 build
            • Uber E30
              • 1409
              this is 100% true
              Even the wiki has a pretty basic list which is linked on this forum.
              -Alex
              • Stu
                • 4083
                Well put.
                • rThor432
                  • Feb 2007
                  • 3907
                  Yeah I never posted once asking about what was needed or how to do the swap.. and I used this site almost exclusively for information. I checked the info I found here against other info found other places, but everything you need is here on this site.
                  • e30s50dan
                    • Nov 2008
                    • 2076
                    yeah
                    NASA
                    BMWCCA member
                    PCA member 25yrs
                    1991 318IS slick top
                    1997 M3 sedan
                    2001 325CI DD
                    “whoever turns the wheel the least, wins"
                    • z31maniac
                      • 17566
                      People will be more willing to help you out if you are confused about a particular hose/wire/part when it's obvious that you've at least put some effort into to figuring out what is necessary.
                      www.gutenparts.com
                      • Luis325
                        • 3847
                        Man ive been reading up on this for a while it seems like allot of work...
                        Isnt it easy just to do an M20 Stroker 3.1? Do you get similar results????
                        1986 "C2 2.7 Alpina" Sedan
                        1987 325ic Black Vert
                        • e30s52
                          • Oct 2007
                          • 5235
                          no and search
                          www.gutenparts.com
                          • red325
                            • 961
                            s50/52>3.1
                            • Luis325
                              • 3847
                              Ive searched allot just not convinced its worth it.......
                              Ive ridden in a 3.1 strocker and the same owner has a e36 m3 with the s52 with a few
                              few boltons and the e30 is way faster.......
