HALP!!! Ebay long tube headers will not clear!!!
  • gazellebeigem3
    • Jun 2005
    • 3712
    #31
    Originally posted by MR 325
    Removing the engine mount arm heatshield (and possible slight grinding of the arm) will help with clearance.
    yup, ive had to do that on three sets.
    • bykerboy
      • 152
      #32
      Originally posted by Karlspackler
      I was actually wondering how far I can lift/tilt the motor while still attached to the motor mounts.
      You should easily be able to lift it a couple of inches.
      • e30Rob
        Master of Adaptation
        • 1182
        #33
        little late on response as seems like you've got a bit of help already.
        I had this same issue, now i know this sounds silly but hear me out.
        take weight off motor
        remove motor mount arm
        install header
        reinstall motor mount arm
        Like i said i know it sounds silly but i ran into this same exact issue... removed the motor mount arm attached the header, and put the arm back on and it cleared perfect. No beating or bending was required.
        -Rob
        Need Custom spacers and adapters?
        PM for information
        • AlarmedBread
          • Sep 2006
          • 1510
          #34
          install header
          +1
          I ran into this same issue on the engine stand and it looked like either do that, or pull the head studs to install it. Once in place clearance is tight and you have to use a wrench on one of the bolts to the block, but it fits.
