HALP!!! Ebay long tube headers will not clear!!!
  • Karlspackler
    • Jun 2006
    • 510
    Mind you this is in my e30 m3 not a regular e30 but I thought they were basically the same mount wise.
    OBDI S52 with E34 motor mounts in my E30 M3.
    I bought these:
    http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
    They were the ones quite a few people recommended on this forum.
    The shorter one closer to the firewall clears perfect but the front one hits the motor mount.
    Anyone have some advise?
  • zav3n
    Curious George!
    • Mar 2007
    • 223
    heat up that pipe and bend it....
    • Van Westervelt
      • 9365
      Small small shim. Hadnt heard of using e34 mounts either. Hmm. I used the e28 mounts, and Supersprint headers, no issues.
      I think those are a copy of the Supersprints right?
      • Karlspackler
        • Jun 2006
        • 510
        How exactly will that work? I cannot even get the header onto the flange bolts as it hits.
        I think we are going to try and pry/lift the motor a little to see if we cannot get them on.
        • e30s52
          • Oct 2007
          • 5235
          Yes they are replicas. I had to heat up my subframe and beat it with a BFH to make alittle room. I tryed to bend the pipes alittle but that wasnt going to move at all.
          O and I think you are using the wrong mounts and thats why it isnt working.
          www.gutenparts.com
          • z31maniac
            • 17566
            My replica ones weren't clearing the arms either.
            Thankfully I lucked into a set of TMS shorties with a custom downpipe.
            www.gutenparts.com
            • Karlspackler
              • Jun 2006
              • 510
              do u have a picture of the ones I am supposed to be using? The PO said they are e34 mounts.
              I might try the BFH too
              • e30s52
                • Oct 2007
                • 5235
                http://www.realoem.com/bmw/showparts...60&hg=11&fg=10
                #12 is what you need sir. The BFH works really well.
                www.gutenparts.com
                • Karlspackler
                  • Jun 2006
                  • 510
                  As I suspected, the guy doesnt know what he is talking about. Those are the exaxt same mounts I have so no problems there
                  • e30s52
                    • Oct 2007
                    • 5235
                    Do you have them turned the right way? The longest bolt should be facing up.
                    www.gutenparts.com
                    • Karlspackler
                      • Jun 2006
                      • 510
                      pretty sure, here is a pic:
                      • Karlspackler
                        • Jun 2006
                        • 510
                        In the ebay link I posted, look at the pics at the bottom.
                        The longer one has to go in front right?
                        • e30s52
                          • Oct 2007
                          • 5235
                          Yes the longer header goes on the front and the shorter one goes on the rear. Which ever side is the longest that is the side that faces up right. The e28 mount needs to be turned upside down.
                          www.gutenparts.com
                          • JGood
                            • Jan 2004
                            • 7959
                            Yes, longer one in the front. They should both exit at almost the same spot.
                            You have e36 motor mount arms with e28 motor mounts. Can be confusing...
                            I didn't install mine with the motor mount in place. I do know that I was unable to tighten the motor mount nut with the headers installed though. No combination of wrenches/sockets/swivels/extensions would fit. I ended up double nutting it so I could reach the top nut with a wrench, turned it until I couldn't anymore, and said a prayer.
                            *edited for wrongness*
                            e30 restoration and V8 swap
                            24 Hours of Lemons e30 build
                            • Karlspackler
                              • Jun 2006
                              • 510
                              So are you saying I need to turn mine upside down?
