F1 Racing Prolite flywheel s5x Advisory.
  • 7pilot
    • 475
    S50/2 engine, sachs disc, pressure plate, with ZF 320 5sp..
    This is an advisory for any DIY types using this flywheel.
    It is a nice looking chromoly 16Lb unit.
    The price is good...the "bay".
    The problem with it is that it pushes the clutch disc about 3.5 mm further back towards the transmission.
    Coincidentally, the throwout bearing guide tube has an id of a smidge more than the nose of the Sachs clutch hub.
    When you use this flywheel, you end up with the guide tube "swallowing" 3-3.5 mm of the disc hub.
    The car will turn over/ start then die right away.
    Your attempts to restart will be met with a heavy clunk as the tube and disc have welded themselves together.
    Of course the engine is locked in both directions.
    You'll have almost as much fun as I did, trying to separate the conjoined engine/trans assembly.:mrgreen:
    m
  • StereoInstaller1
    GAS
    • 22679
    can we get a link?
    Closing SOON!
    Thanks for 10 years of fun!
    • JGood
      • Jan 2004
      • 7959
      can we get a link?
      To what, the flywheel? The brand name is F1 Racing and it's on ebay...
      http://cgi.ebay.com/ebaymotors/F1-RA...Q5fAccessories
      e30 restoration and V8 swap
      24 Hours of Lemons e30 build
      • lifeiskaos
        • 1709
        e36 guys use this all the time with no problems...
          • 37833
          Grover Beach, California
          BimmerHeads.com
          • etxxz
            • Feb 2006
            • 2085
            ...shiii. what did you install backasswards?
            i has it....two years, no prob.
            No more e30s for me.
            88 black BMW OBDII 332is dedicated track [sold]
            88 BMW OBDII bronzit 332is [RIP 03/08]
            91 BMW 325i [sold]
            86 Corolla 'Ae86' HB 20v trd [sold]
            http://youtube.com/watch?v=pTj7Hn9v5Rs
            • Farbin Kaiber
              Lil' Puppet
              • 29502
              Pics of your failure?
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                Found.
                • 7pilot
                  • 475
                  That is why I risked buying it :?.
                  Otherwise I was looking at the major LTW Vendors.
                  m
                  Btw, I have quite a bit of experience, so I was pretty tee'd at this failure.
                  I don't believe my engine would have remained running.Fuel pump sitting for 3 years.
                  There's a chance that with an eager to start engine and a big battery and some throttle, it would machine itself some clearance.
                  • Mossman
                    • Apr 2006
                    • 1961
                    I recall reading about one of the cheap ebay flywheels requiring you to install the clutch disk backwards, is it this one, and did you install it regular or backwards?
                    • 7pilot
                      • 475
                      Interesting.
                      The backwards install would cause the clutch disc hub to contact the flywheel.
                      Asking the customer to install parts in a manner that they were not designed for is just too sorry.
                      They failed to measure the depth of their flywheel...Very basic procedure....Lazy gits.
                      I believe that when you install the disc in its correct orientation it also supports the input shaft of the trans correctly, in conjunction with the pilot bearing.
                      Oh well.
                      Just as long as people are aware of this problem.
                      m
