Hey guys
I have posted about this before but still have not figured out what the cause is....
I have a 97m3 engine with obd1 swapped into my e30. I purchased the car with the swap done two years ago but have yet to figure out why my car has starting issues "only sometimes."
Usually when the car has been running for a bit, then turned off for 5-20 minutes(could be less could be more) or so- when I got to start it, it fires right up but then stumbles and dies within about 5 seconds. if I startit again right after it starts up and idles/runs fine.
What could be causing this?
I cant find any vacuum leaks and the only thing I feel like I havent replaced is the FPR. Usually the FPR though will make it hard to start which is not the case.
It was throwing a code for the MAF last week, I replaced it and it continued to show the code but has since gone away. It now is showing a code for the o2 sensor as of this morning. It could have been that I was messing with the intake side and it went to a lean/rich condition when I pulled a vacuum line though.
Any help would be great.
Jeff
Jeff
