Car starts fine then stumbles and dies
  • BlackE30
    • Sep 2004
    • 605
    DME did not fix the problem. Its some kind of fuel flowing issue, When this happens it sounds like the fuel pump is working overly hard to keep it from dying.
    • jahnaboi
      • Oct 2006
      • 1742
      Ever figured your problem out?
      SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
      • hoveringuy
        • Dec 2005
        • 2752
        This is an old thread, but I have a pretty good idea having just gone through the same thing.
        • dranttna
          • 127
          i've seen similar problems from a slow reacting ect, not on a 24v bmw though so im not sure how the computer would handle that...
          just a thought
          325es/24v's/20psi/meth injection/
          • 7pilot
            • 475
            TPS maybe? The ECU does not know where idle is on restart.
            I would test the TPS, then fiddle with adjustment.
            Does the car smell gassy when warmed up?...CTS
            m
            • BigD
              • Jul 2006
              • 1085
              Looks like a fuel issue to me. The fact that it's worse when hot really supports that. When an engine is cold, the ecu will open the injectors longer so it will be more willing to run when cold. The O2 code is probably because it's trying to richen the mixture to compensate but is unable, so it probably means the O2 sensor is full of shit (or so it thinks).
              What are the details of the OBDI conversion? Did you use the pink injectors? Did you get a proper chip? (the stock tune is for a 2.5L engine with 19 lb injectors).
              • graphikg
                • Jan 2008
                • 1614
                Mine does kinda the same thing right now, but I think its a timing issue. It starts and dies right away. I think the timing is very off.
