CSB Swap?
  • e30 blue
    • 69
    CSB Swap?
    Okay a 85 with the m10 and m50 with 328I ZF, Drive shaft to install and I read in the search, Fred said that you need to change the CSB to a E30 Why. Do I order one for a m10 driveshaft ? Is the M10 and 328i driveshaft the same diameter?
  • FredK
    • 14764
    Yes, you will need a CSB from an early model car, as the spacing changed for facelift E30s. The bearing is the same diameter between the E30 and E36, but the bracket bolt spacing that secures the CSB to the transmission tunnel is different.
    • e30 blue
      • 69
      Thanks Fred, So if I order a new 1985 318i CSB and take the 328i driveshaft to a shop , they should be able to change/ press the csb's for me , correct?
      • FredK
        • 14764
        Yep! Just duplicate the orientation so the shaft stays centered in the transmission tunnel. I don't know what an early model CSB looks like, but there is definitely a correct and incorrect orientation to the late model CSB.
        Hopefully someone has a picture somewhere.
        • e30 blue
          • 69
          Thanks again Fred for schooling me , so I now know what to do. I will find a driveshaft shop and ask them to keep the change over the same,so it should be done the correct way .
