Overheated!!!!
  • lennon
    • Jun 2008
    • 1416
    #31
    i doubt its the radiator cap. have you taken off the intake manifold yet?? your eyes are your best tool here.
    • hoveringuy
      • Dec 2005
      • 2754
      #32
      There is no way it's the radiator cap.
      Take off the manifold, a little talcum powder (or flour, your choice) and you'll find the source.
      • gazellebeigem3
        • Jun 2005
        • 3712
        #33
        You really should look at all the coolant lines on etk for your motor to get familiarized. Then follow them with a flashlight and mirror. If its leaking that bad it should be easy to see.
        The other option is an externally leaking headgasket. I had to do mine this summer because it was leaking at the back of cylinder 6. At first I thought it was the pipe on the back of the head. Sadly it required at bit more time and $$$.
        • graphikg
          • Jan 2008
          • 1614
          #34
          Why would it go away when I replaced the cap then? I dont understand. I drove it for a month and put at least 1200 miles on it! No Leaks. Now the thing is back!
          Its going to break my heart to know that my fresh 14k miles on rebuild motor is experiencing a head gasket leak. Any help in the CA, north bay?
          • gazellebeigem3
            • Jun 2005
            • 3712
            #35
            After looking at the video, i would pull the intake out of the way. my moneys on the spider hose
            • graphikg
              • Jan 2008
              • 1614
              #36
              Know of a writeup as to how to pull that intake out? and if you think it is spider hose, could that be an explanation as to why my heater does not work... No hot air coming into cabin. Thanks for the help!
              • SamE30e
                • Sep 2007
                • 4319
                #37
                Intake is pretty easy. You can see all the bolts from the top of the engine. Just disconnect everything attached to it.
                1985 325e 2.8 Turbo VEMS
                • jrdeamicis
                  • Nov 2008
                  • 956
                  #38
                  Absolutely. Please call me @ 848-248-8029
                  Past Car : E30 S50 6 Speed 5 Lug 3.73
                  Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                  ___________________________________________
                  BNB Designs
                  Engine Swaps, Fabrication, Innovation, General Repair
                  Richmond CA
                  Julian 848-248-8029
