whats needed to make m50 reliable for d/d
  • TurboFox93
    • 173
    I am getting ready to swap in an NV M50 from a 92 325i with 130k miles. Short of a rebuild, what items should I replace to have a worry free daily driver. The car previously drove with out issue but I am unaware how diligent the previous owner was with maintenance. I appreciate any suggestions.
  • vivalegreg
    • Apr 2006
    • 1313
    well, im sure if you do some searching you can find out the service intervals and what they entail for an e30 chasis and then for an e36 engine and make sure the car is up to date with maitenance. i would def recommend revising some suspension components and possible rack install while you have the engine out..new clutch components..a good cooling system...detail engine bay...etc...
    e30s r kool
    • FredK
      • 14761
      Waterpump, thermostat, and thermostat cover (if it is the original plastic cover, it will crack).
      • e30s50dan
        • Nov 2008
        • 2076
        and change rear/front seals plugs/etc
        NASA
        BMWCCA member
        PCA member 25yrs
        1991 318IS slick top
        1997 M3 sedan
        2001 325CI DD
        “whoever turns the wheel the least, wins"
        • jrdeamicis
          • Nov 2008
          • 956
          F&R main seals
          Complete cooling system overhaul
          New Knock sensors (a bit overkill but shitty ones will pull timing)
          VCG
          Oil Pan gasket
          Front timing cover gaskets
          New Timing chains upper and lower
          All new tensionsers
          Locktite oilpump nut
          New injector o rings
          New intake manifold gaskets.
          You could just order a top end and bottom end rebuild kit also for most of the gaskets and have a spare headgasket sitting around.
          Only get elring.
          Past Car : E30 S50 6 Speed 5 Lug 3.73
          Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
          ___________________________________________
          BNB Designs
          Engine Swaps, Fabrication, Innovation, General Repair
          Richmond CA
          Julian 848-248-8029
          • Spaz
            Crazy Canuck
            • 2276
            Originally posted by jrdeamicis
            F&R main seals
            VCG
            Oil Pan gasket
            All new tensionsers
            Only get elring.
            I'd agree with this list, but i'd skip the chains, and just do the timing chain Tensioners
            Cam .W '91 325is
            Spaz's 1991 Alpine White???? S52 Build Thread...
            • rThor432
              • Feb 2007
              • 3907
              Like a few guys have said, the cooling system is very important. It's really the main weak point of these engines as far as reliability is concerned.
              I agree with the post by Spaz, and wouldnt necessarily replace the timing chain guides. I would do those if I were rebuilding an engine or if the engine I was installing had 200k+ on it (I'd probably be rebuilding at that point anyway...). I hardly ever see timing chain guide issues on these issues, it's very rare. Tensioner is a different story though.
              Take care of the cooling system, oil leaks, and make sure you have an aux fan, mechanical fan, or both and you will have a very reliable setup.
              • SamE30e
                • Sep 2007
                • 4319
                The M50NV has knock sensors?
                1985 325e 2.8 Turbo VEMS
                • rThor432
                  • Feb 2007
                  • 3907
                  I think he over-looked the "Non-Vanos" part and was just mentioning an overview of maintenance that will help the M/S5x family motors live a long life.
                  • e30s50dan
                    • Nov 2008
                    • 2076
                    Originally posted by same30e
                    the m50nv has knock sensors?
                    no
                    NASA
                    BMWCCA member
                    PCA member 25yrs
                    1997 M3 sedan
                    2001 325CI DD
                    • jrdeamicis
                      • Nov 2008
                      • 956
                      I did. I apologize. I wouldnt even think about swapping in NV. The M20 has cheaper parts, everything fits, and not as much trouble at times.
                      Also with the timing chains. Think of it this way. If you have any problems with your timing chains (mostly the rails on the primary have the problems) the whole front of the motor is coming apart to fix it. The rail is cheap (ish) along with the chains. If you want it to be reliable thats what I would do.
                      I would also pop the head and do new valve stem seals and an elring headgasket. Perfect time for the front timing system refresh.
                      BNB Designs
                      Richmond CA
                      Julian 848-248-8029
                      • rThor432
                        • Feb 2007
                        • 3907
                        I absolutely agree with this statement, by the way. Swapping in a NV motor doesnt make sense to me and I dont think it is worth the effort at all.
                        • jrdeamicis
                          • Nov 2008
                          • 956
                          And the NV doesn't have many upgrade options (not counting turbo). But who wants a giant snail complicating things for a DD?
                          BNB Designs
                          Richmond CA
                          Julian 848-248-8029
                          • Adrian_Visser
                            • Jun 2006
                            • 2823
                            wait NV doesn't have knock sensors? I learned something today...
                            '89 Alpine S52 with goodies
                            • MIKe30
                              • Sep 2006
                              • 2334
                              I'd say don't waste money on an m50. Find one that's been running well, drive it before you buy it if you can - at minimum do a comp test on it. Replace the cooling as FredK said and throw the bitch in. You'll be happier in the end.
                              If you want to refresh and blah blah, save up for an m52 and do it. you'll be more likely to keep that motor in there longer. just my .02
