What "bolt ons" bring an s52 to 300hp and what's the cost?
  • clydesdale
    • 631
    I am zeroing in on an s52 swap and I am still trying to decide :
    s52 obdII
    s52 obdI
    S50
    From what it seems the s52 obdI may be best and I hear you can make it 300 hp with bolt ons. Can you tell me what they are and their cost. Also, will this challenge the reliability of the motor? Thanks.
  • z31maniac
    • 17566
    Cams, good headers and exhaust, 3.5" MAF, possibly bigger injectors, GREAT tune won't get you to even 300hp at the crank.
    Unless there is a set of cams out there, that without headwork, are going to pick up 30-35 over stock cams.
    300whp isn't going to happen with anything less than a high-comp race build.
    www.gutenparts.com
    • sharky
      • Jan 2005
      • 2672
      truth, not gonna happen, you can but it will cost big money to build and it will still barely hit 300 crank and that is a BUILT engine. S52 OBD1 + AA or VF supercharger = well over 300 rwhp without breaking the bank.
      • e30polak
        • 6136
        Full bolt-ons and cams on an OBD1 s52 can make 300+ crank hp.
        Cams are the ultimate factor, and they also give you different powerbands
        Schrick - have the widest powerband out of the 3 options, but make less peak power
        Sunbelt - make more peak power, but have a narrower powerband then the Schricks
        Evosport Race - require an upgraded valvetrain, but are capable of 280+whp. Problem is they're so aggressive that you will rob a lot of the low end power to make up for it above 4k.
        3.5" MAF
        24# injectors
        A proper intake and filter set-up
        euro headers mated to a properly tuned exhaust
        PS delete
        AC delete
        Underdrive pulleys
        A good tune
        INSTAGRAM: @UNDR8D_EMPIRE
        • mazur
          • Jan 2006
          • 731
          Remove the S52 and bolt on an S54.
          • e30s50dan
            • Nov 2008
            • 2076
            HAHA or a S38
            NASA
            BMWCCA member
            PCA member 25yrs
            1991 318IS slick top
            1997 M3 sedan
            2001 325CI DD
            “whoever turns the wheel the least, wins"
            • z31maniac
              • 17566
              3.5" MAF
              24# injectors
              PS delete
              AC delete
              Underdrive pulleys
              A good tune
              I have TMS equal length and no underdrive pulleys (but no PS or AC), but the 3.5" MAF, 21.5# injectors (TRM claims they are good to 250whp or about 290 crank), full 2.5" mandrel exhaust with straight through muffler, cleaned/flowed injectors and a TRM tune.
              Put 232whp or about 266 at the crank. Are Schricks/Sunbelts/EvoSport (non-race) really going to pick up 35+ HP? Most stuff I've seen puts Schricks at about 15-20whp more than stock.
              Your claim about the EvoSport race cams 280whp is around 322 at the crank. So the EvoSport race cams are worth 60+ HP at the crank? With no headwork?
              www.gutenparts.com
              • jrdeamicis
                • Nov 2008
                • 956
                a super charger bolts on.
                Past Car : E30 S50 6 Speed 5 Lug 3.73
                Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                ___________________________________________
                BNB Designs
                Engine Swaps, Fabrication, Innovation, General Repair
                Richmond CA
                Julian 848-248-8029
                • clydesdale
                  • 631
                  Ok can someone do a breakdown on the hp gain for me? For example:
                  Exhaust 5 hp
                  cams 30 hp
                  etc.......
                  And the approximate cost. I am trying to figure out where I should head with my swap plans and what is attainable. Above all else it must be a reliable DD and not obnoxiously loud.
                  • Jean
                    • 18228
                    Doesn't work that way.... you can't just add up possible (peak) hp from every mod like 1 + 2 + 3 = 6 etc.
                    If you want 300hp daily drivable (read not something you have to rev the piss out of it, or will idle funny or not pass smog) you'll want to do an s54/s38/v8 swap or proven supercharger route.
                    • e30polak
                      • 6136
                      Plenty of people have made 250+whp, on Schricks on OBD1 and OBD2 s52s without headwork (a few have broken 260whp with headwork). Sunbelts are capable of 255-265 whp, up to 278whp with euro headers and headwork.
                      As far as the Evosport cams go, they aren't streetable. They have 292/292 duration, which causes you to lose A LOT of low end torque. Those cams really scream past 4500 though. Evosport made 308whp on those cams NA. Obviously they require upgraded valve springs and retainers at the minimum.
                      • z31maniac
                        • 17566
                        Man I wish I could justify $2k on Sunbelts and a tune.....
                        www.gutenparts.com
                        • BingM3
                          • 863
                          There are used S/C kits on ebay, and craiglist, etc...which can be had for $ 2000-3000
                          Bolt it and forget it!
                          • clydesdale
                            • 631
                            ok, I think my 300hp notion was just crushed. Stock is about 240 correct? Than I will probably stick with that. It must idle nice, be quiet and very reliable. I don't think too many have done the s54 correct?
                            • WADE30
                              • 249
                              Are you talking about engine power here?
