Hello everyone,
This is my current issue im doing the clutch on my m50 and it had a dual mass flywheel and i figured while i was doing the clutch i wanted to do a single mass flywheel conversion, so i used a m20 clutch and flywheel, the issue i am having now is the clutch fork is making contact with the outer edge of the pressure plate i was thinking i probably also have to use a m20 clutch fork? This set up is currently in a e34, but i have a zf320 in the e34, and i figured some of the 24v guys on here would know since there are some simliar set ups
-Thanks Dan
-Thanks Dan
