24v M50 airbox
  • e30s50dan
    • Nov 2008
    • 2076
    24v M50 airbox
    well, i messed around at the junkyard last weekend looking at airboxes.E34'sE36's,530 and a 540..brought home 2..one from an E34 and another from an 528e..well the E34 wouldnt fit because of the ABS,but the 528e fit fine,with little modification..
    NASA
    BMWCCA member
    PCA member 25yrs
    1991 318IS slick top
    1997 M3 sedan
    2001 325CI DD
    “whoever turns the wheel the least, wins"
  • richardb
    • 2121
    That's a cool idea, but it looks like it's not parallel with the car, like it's cocked slightly. That would drive me crazy! If you search someone used a 535i box guttend and shortened as a heatshield for the k&n cone filter, it looks sick
    Transaction Feedback!
    • Spaz
      Crazy Canuck
      • 2276
      Hmm i gotta find that now :|
      Cam .W '91 325is
      Spaz's 1991 Alpine White???? S52 Build Thread...
      • dude8383
        • Jan 2005
        • 10387
        that looks pretty good, i think if you were to play around with that bracket you could get it to align properly. i've seen people use the m20 airbox.
        what kind of adapter plate are you using for the airbox to intake piping?
        • jahnaboi
          • Oct 2006
          • 1742
          Looks nice.
          Question: Would the flow rate of the m20 airbox be sufficient enough for a s50/s52?
          SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
          • e30s50dan
            • Nov 2008
            • 2076
            its not that crooked...its close to the Alt.but lines up good with the MAF.the inlet hole of the box lines up with the inlet hole of the headlight cover
            NASA
            BMWCCA member
            PCA member 25yrs
            1997 M3 sedan
            2001 325CI DD
            • screwbiedoo15
              • Aug 2009
              • 79
              If you find it could you post the link in here? I'm interested to see how this looks as well since I have an extra E34 535i airbox lying around.
              • richardb
                • 2121
                • flyboyx
                  • 8371
                  i like that bracket you fabricated. i wanted to do something stock looking, but in the end i decided to go with that cylindrical carbon fiber cold air intake that one of the members sells for about a hundred bucks. it doesn't look very stock, and the supplied mounting bracket needs to made stronger, but i think it is one of the best choices available. with that said, i do like what you have done. a k&n filter inside there wouldn't hurt anything, either.
                  Gigitty Gigitty!!!!
                  • e30s50dan
                    • Nov 2008
                    • 2076
                    thanks..I have a total of $22 in it..adapter and 3" hose from auto zone
                    NASA
                    BMWCCA member
                    PCA member 25yrs
                    1997 M3 sedan
                    2001 325CI DD
                    • 2002maniac
                      • 4260
                      looks very similar to the M42 airbox
