Clutch Recommendation for S52 Swap
  • 91E30-318is
    • Apr 2009
    • 34
    I'm getting closer and closer to completing my parts collection for my swap.
    I've sourced everything but a M3 Transmission. It shouldn't be too hard to get a hold of one.
    My question is what clutch works best for the street and doesn't break the bank? The kits I've been looking at are Stage 2 clutch with 16.5 lb fly wheel.
    My s52 will be mostly stock, do you really need to spend $700 - $1,100 for a clutch set up?
    Will the $500 stage 2 kit work well?
    Thanks for your advice.
  • 416stroker
    • May 2008
    • 2448
    Oem will be fine.
    Id just go wit all m20 stuff flywheel clutch and pressure plate.
    84 318I Delphin RIP
    87 325IS delphin 24v Sold
    89 325 Alpineweiss
    • dude8383
      • Jan 2005
      • 10387
      I have a stock 325i sport and the 16lb single mass flywheel and I think its more than adequate.
      http://cgi.ebay.com/ebaymotors/SACHS...#ht_2858wt_933
      http://cgi.ebay.com/ebaymotors/F1-ST...#ht_2766wt_933
      http://cgi.ebay.com/ebaymotors/F1-ST...#ht_2665wt_933
      All of the above should do.
      • FredK
        • 14761
        I used a heavy dual mass flywheel and stock clutch. I like it, and I never had an issue with it slipping.
        • jahnaboi
          • Oct 2006
          • 1742
          Originally posted by fredk
          i used a heavy dual mass flywheel and stock clutch. I like it, and i never had an issue with it slipping.
          +1
          SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
          • z31maniac
            • 17566
            I used a lightened M20 flywheel with custom clutch setup. Had a local company here in town do all the work and build the disc.
            The whole deal cost around $270 for the flywheel work/pp/disc/to bearing/alignment tool.
            www.gutenparts.com
            • sharky
              • Jan 2005
              • 2672
              Finzanza 13lb w/ stock M3 clutch and PP about $540 total
              • balooshinakus
                • 511
                Stock m20 clutch with an m20 flywheel shaved to 12lbs, stock pressure plate, no issues.
                • etxxz
                  • Feb 2006
                  • 2085
                  ^^ stock clutches are the best option for stockyish s5x swaps. even for those who track them. f1 (ebay) chromoly ltw flywheel and sach's (oem) clutch on my ZF and thausands of miles of track time. Great on the street, great on the track... great on the wallet.
                  No more e30s for me.
                  88 black BMW OBDII 332is dedicated track [sold]
                  88 BMW OBDII bronzit 332is [RIP 03/08]
                  91 BMW 325i [sold]
                  86 Corolla 'Ae86' HB 20v trd [sold]
                  http://youtube.com/watch?v=pTj7Hn9v5Rs
                  • rThor432
                    • Feb 2007
                    • 3907
                    ^^I agree with this.
                    That's what I'm running. It's an excellent setup. All pros no cons.
                    • MattM
                      • Apr 2009
                      • 931
                      yup, im running E36 dual mass, stock clutch, no issues
                      Full Build Thread Here
                      • lifeiskaos
                        • 1709
                        i recommend the third one with the sprung hub clutch disk. it will greatly help clutch engagement. plus the auction is "buy it now or best offer" so you can likely lowball them for a better price
                        • 91E30-318is
                          • Apr 2009
                          • 34
                          Cool! Thanks guys.
                          There are so many "stages" out there.
                          I'm assuming the difference is in how heavy the clutch pedal is, the pick up point and how much power it can take.
                          • BingM3
                            • 863
                            Stock E34M4 clutch works fine!
                            • White325is
                              • Oct 2006
                              • 5947
                              Euro 323 flywheel and stock M20 sachs clutch kit works fine here. I havent had any problems with slipping either.
