will an S52 replacement work for my S50?
    • 37834
    I use the Zionsville manifold so I didn't have to drill the head. Hose from head to manifold, spider hose to manifold. No TB circuit.
    WOW, I had no idea that even existed. Pretty cool option for those running an OBD1 M/S52!!
    Here's the link for anyone interested...
    Grover Beach, California
    BimmerHeads.com
    • z31maniac
      • 17566
      Just make sure to Teflon tape the sensor and get it nice and tight.
      Ask me how I know.....
      www.gutenparts.com
      • BlUe E30
        • Jun 2008
        • 180
        bump
        • BlUe E30
          • Jun 2008
          • 180
          how do you know? and i am going to purchase that piece tonight that is something i was thinking about trying to do thanks!
          and unfortunately i didnt get it in over thanksgiving when i pulled out the s50 i found out the m50 oil pan was cracked.
          would you suggest while im in there with the new oil pan to secure the oil pump nut?
          • e30s52
            • Oct 2007
            • 5235
            Yes!!!!! get it welded or safty wire.
            www.gutenparts.com
            • z31maniac
              • 17566
              Thought it was tight, it wasn't, coolant system got pressurized, big time leak. Pulled it out, cleaned/dryed it off, hit the sensor threads with some teflon tape and really screwed that bitch down tight.
              www.gutenparts.com
              • BlUe E30
                • Jun 2008
                • 180
                will do the safety wire no access to a welder at this point in time and ill definately make sure to get it in tight then with tape thanks
                • BlUe E30
                  • Jun 2008
                  • 180
                  bump
                  • BlUe E30
                    • Jun 2008
                    • 180
                    ok this may be a stupid question but i bought that part from Zionsville and im looking at it and not 100% sure on how to hook it up... any help?
                    • BlUe E30
                      • Jun 2008
                      • 180
                      bump
                      • z31maniac
                        • 17566
                        What I did was delete the throttle body warming circuit. Used on hose to connect the head to the manifold, then a hose to connect the manifold back to the "spider hose"
                        Take a small wire and eyelet and screw it into the manifold (there should be a screw in the hole), then ground that to the engine (I grounded it to the engine lift hook) then connect the sensor to your wiring harness.
                        Super easy.
                        www.gutenparts.com
