Forum Friendly help diagnosing idle issues in/around Atlanta?
  • clarkbmw325is
    • Mar 2007
    • 267
    Is anyone in/around the Atlanta area available to help me diagnose the erratic idle in my car? It's getting pretty frustrating trying to heel 'n toe it through traffic.
    Running a OBDI s52 with a 540i HFM...
    From searching through the various threads on this very topic, I know two common culprits are the gunked up ICV and the wire from the AC compressor to the DME. However, the erratic idle happens with the AC either on or off...
    Just looking for a little experience to pull from... Thanks.
    -John
    '87 Delphin OBDI S52, 5-lug 325is-SOLD
    '81 CJ-7 w/ SBC 350 conversion
    A.D.D. mastermind...
  • matt
    • 3732
    I could take a look for you. PM me your #. I work in Marietta. :)
    • clarkbmw325is
      • Mar 2007
      • 267
      Shot you a PM Matt. Thanks.
      • z31maniac
        • 17566
        So have you checked the ICV? I'd also check your vacuum connections as a starting point.
        www.gutenparts.com
        • clarkbmw325is
          • Mar 2007
          • 267
          Dad changed out the ICV out a week ago while it was in NC...with no success at evening out the idle. I wasn't there to check the condition of the 'new ICV'.
          I'm going to take it out tonight and examine/clean it. Fingers crossed that it's as simple as that.
          • matt
            • 3732
            You should look for a vacuum leak also. Make sure you have all the ports on the manifold plugged or connected.
            Do you have a chip for the 540 MAF?
            • clarkbmw325is
              • Mar 2007
              • 267
              Yep, chip accounts for the 3.5" MAF. I think it's Jim Conforti.
