FML... Went to start my car up for school this morning and no start.
  • jahnaboi
    • Oct 2006
    • 1742
    Definitely fuel related. Usually when I start up my car, my fuel rail is primed before ignition, but I didn't hear anything this morning. Sprayed starter fluid, and it started right up. Shit cost me an absentee for my Physiology class.
    Possible fixes from what I can see:
    - Faulty pump / filter
    - Bad connection/power lines to fuel pump
    - Faulty injectors (highly doubt it)
    Bare in mind, car ran great before I parked it in my garage 2 days ago. I did nothing to it to make anything change. Just drive and park, drive and park.
    If it is the pump, can you say Walbro 255? =)
    SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
  • jahnaboi
    • Oct 2006
    • 1742
    Well to eliminate everything, I went and checked the fuel pump. I'm getting power to the pump while in ignition but there is no hum or buzz from the pump. Dead pump? I think so. Will power it directly, be back shortly. (Even though I'm talking to myself on this thread. Haha)
    • FredK
      • 14764
      That happened to me before. Parked, went inside a place, came back out, no-start. It was a bad connector.
      • jahnaboi
        • Oct 2006
        • 1742
        I wish it was a bad connector. The connector was in perfect shape till I broke the old crummy hardened plastic housing. I used a voltmeter to check if the fuel pump was getting power when cranking the motor (ignition). I got 11.68 volts while cranking from the power connector that connects to the fuel pump but nothing was happening at the fuel pump. Even jumped direct power to the pump itself and still nothing happening.
        I'm safe to say its my fuel pump. Sigh...
        • FredK
          • 14764
          Did you try pounding on top of the fuel pump? Sometimes this gets them to run long enough to get a replacement.
            • 37834
            ^ This. Also can slam on the bottom of the tank with a rubber mallet.
            Grover Beach, California
            BimmerHeads.com
            • lifeiskaos
              • 1709
              LOL. I love this advice. If something doesn't work, hit it harder until it does :D
              <3 e30 owners
              • FredK
                • 14764
                Well, sometimes it becomes a matter of survival. For example, my fuel pump connector was flaky, but pounding on it allowed me to drive right on home until I could figure out what was really wrong. I don't recommend it as a long-term solution, of course. :D
                • jahnaboi
                  • Oct 2006
                  • 1742
                  Lol... If anyone has a new walbro 255 on hand for sale let me know... I'll try hitting the bitch.
                  On hand meaning I could drive to pick it up locally. =)
                  • JGood
                    • Jan 2004
                    • 7959
                    You can try to reverse the polarity to get a pump going again too. Reverse it, give it power, tap it, reverse it again, power, tap it, etc...
                    I've had luck getting a few more miles out of pumps by doing the above procedure. Dirt seems to get built up within the motor/propeller, and this might dislodge it. It may be just enough to get the car to a place where you can safely work on it or whatever.
                    If it's just the brushes, tapping on it may do the trick for a few miles as well, like others have mentioned.
                    e30 restoration and V8 swap
                    24 Hours of Lemons e30 build
                    • FredK
                      • 14764
                      Stop lying JGood. You know you're still using that pump after cleaning it out with some kerosene.
                      jk
                      • jahnaboi
                        • Oct 2006
                        • 1742
                        I took the pump out, reversed it till there was no more fuel within the pump and slapped it back in and it actually worked. Interesting...
                        • jrdeamicis
                          • Nov 2008
                          • 956
                          Good to know.
                          Past Car : E30 S50 6 Speed 5 Lug 3.73
                          Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                          ___________________________________________
                          BNB Designs
                          Engine Swaps, Fabrication, Innovation, General Repair
                          Richmond CA
                          Julian 848-248-8029
                          • JGood
                            • Jan 2004
                            • 7959
                            jk
                            Dude, I wish. I've been through 4 pumps in my track car in 2 years. Every track event it seems like, the damn thing dies. Luckily the early model cars still run with a dead in-tank pump, just don't do so great pulling out of sweeping right hand turns
                            • JGood
                              • Jan 2004
                              • 7959
                              Cool. Don't run it dry for too long, your gas is the pumps cooling system.
