Power Steering with M50
  • JK_E30
    • Jan 2007
    • 545
    Does anyone know if the e30 hoses will fit on an m50 to an e30 rack?
    Thanks.
    M50B25tu
  • 7pilot
    • 475
    I can verify that the E30 M3 hoses work, but the reservoir feed hose to the PS pump needs to be shortened if you relocate the reservoir to the E36 placement on the LF motor mount bracket.
    m
    • shiboujin
      • Feb 2006
      • 2791
      Thanks.
      Will the banjo bolts from the E30 hoses link up to the M50 power steering pump? Yes.
      Will the banjo bolts with all E36 stuff bolt into an E30 rack? Yes.
      • M-technik-3
        • 18946
        If you can afford the E30 M3 lines I would get those, The restrictor is nice allows it not to feel overboosted.
        • e30s50dan
          • Nov 2008
          • 2076
          they shoul ..where are you puting your resevior
          NASA
          BMWCCA member
          PCA member 25yrs
          1991 318IS slick top
          1997 M3 sedan
          2001 325CI DD
          “whoever turns the wheel the least, wins"
          • MattM
            • Apr 2009
            • 931
            yup, just need to shorten the low pressure hoses to the res if you mount in E36 location. I didnt at first and when i got under the car after a short drive the line was kinked and dripping, wasnt so much fun doing this task with a full system and an otherwise spotless engine bay.... LOL
            Full Build Thread Here
            • JK_E30
              • Jan 2007
              • 545
              Thanks for the responses, always helps!
              Leaving the reservoir where it is attached on the m50.
              M50B25tu
              • Kingb
                • 928
                Cool so I have been wasting my time looking for e36 lines.
                Originally posted by Nicademus
                My car beats off to that car. :bow:
                • justin_l_
                  • Jun 2007
                  • 1079
                  Should have asked lol
                  • rpm620
                    • 204
                    all i did was take my E36 p/s res and put it in the factory location on the motor mount arm used the short hose that comes off that hooked right upto the p/s pump and the line from the steering rack takes a bit of bending of the hard line but you can get it to bolt right up
                    E30 Turbo 2.8L - 60ft - 1.70 :: 1/8th - 6.99 :: MPH - 105.47 :: 1/4 - 10.66 :: MPH - 132.53
                    *RIP* E36 M3 - 60ft - 1.944 :: 1/8th - 8.64 :: MPH - 80.00 :: 1/4 - 13.55 :: MPH - 99.95
