anyone use an e30 m3 exhaust?
  • m_dudey
    • 267
    wondering how well it works with the 24v setup with stock s50 midpipes. how's the performance? how's the fit? and how does it sound?
  • 7pilot
    • 475
    Not specifically stock E30 M3 but I'm reusing a E30 M3 VSR twin Cat Mid section and E30 M3 supersprint tail box.
    The E30 M3 Header secondaries are larger in internal diameter than the dual wall OBD 2 M3 pipe.
    m
    • FredK
      • 14761
      The e30 M3 exhaust will have to be modified a fair bit to fit a non-M, enough to make it not particularly worth it IMO. If you can get an exhaust cheaply, then you should be fine. Esssentially, you're paying for a nice dual 48mm - 50mm muffler.
      If you were to fit the muffler in the stock E30 M3 location, the tips will poke WAY out and only one of the stock E30 muffler straps could be used.
      If you were to try to reduce this distance by setting it in closer to the front of the car and utilizing the front muffler strap, you could possibly run into issues clearing the left halfshaft.
      • 1990m3
        • 1180
        m
        VSR center section would be a great setup for a swap car. Tight fit, large pipes, sounds awesome. I love the one on my m3, wouldn't trade it for anything
        • m_dudey
          • 267
          hmm, welding hanging tabs to the exhaust to hang at stock location shouldn't be a problem. I guess the tips would stick out more cuz they're longer. but will the tips stick out of the rear valence cutout centered? or will I have to cut the tips and re-weld them at an angle like other e36 exhausts?
          performance wise, will the e30 m3 muffler be restrictive for the s52?
          I want a sporty note to the exhaust, definitely nothing obnoxious. I had an e30 m3 with stock s14 and stock exhaust before and it was nice. It was sporty loud, a bit raspy though, but not quite obnoxious. I'm wondering if the s52 mated to this will be even louder, though the stock s50 midpipes do have resonators on them vs stock s14 midpipes.
          • Bmjpv
            • Mar 2007
            • 561
            E30 M3 rear muffler
            I installed a M3 rear muffler to replace my very noisey/raspy rear muffler. I found it choked my car down something ferce !!! I have all m3 e36 upstream but the e30 muffler was killed the rev/power ,I had plenty before the swap. Don't do it !! joe
            • m_dudey
              • 267
              what did you have before? any dyno charts? or just according to butt dyno?
