Ze dreaded no start strikes again, help
  • sharky
    • Jan 2005
    • 2672
    OK so I am ready to start the S52 and it it cranking very solid, fuel is all the way up in the lines, fuel supply is hooked into silver hard line, everything is hooked up correctly but it is not starting at all. Any pointers, potential troubleshoots?
  • hoveringuy
    • Dec 2005
    • 2735
    Are the plugs getting wet? Is it sparking?
    • sharky
      • Jan 2005
      • 2672
      Pulled a plug, no spark
      • BenM
        • 2184
        Sounds like the CPS or a grounding issue.
        Originally posted by BillBrasky
        E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
        1991 318i Alpine II - S50/5-lug swapped - track car
        1989 325i Cirrusblau - Daily
        1970 2500 - Malaga over Grey Cloth
        2012 F350 6.7PSD
        • sharky
          • Jan 2005
          • 2672
          The cps was the one you gave me, block is grounded, harness is grounded, dme is grounded w/ 318 dme chassis, what else to look for?
          • BenM
            • 2184
            check the resistance of the CPS. I thought you said you got another one?
            2012 F350 6.7PSD
            • sharky
              • Jan 2005
              • 2672
              sorry, I was thinking cam, yeah I got another crank from a friend that pulled it off his running engine.
              • hoveringuy
                • Dec 2005
                • 2735
                Cam sensor wouldn't keep it from starting. Also, consider my Hall to VR converter. You have a perfectly good Hall sensor in the back of your block.
                • BenM
                  • 2184
                  A potential problem could be the DME Ignition Power (C101 Pin 7, Green Wire). I will try to come over around 5ish on Wednesday and give you a hand.
                  2012 F350 6.7PSD
                  • sharky
                    • Jan 2005
                    • 2672
                    Im working wednesday, mon and tues off from now on. Anyone think it can be a EWS thing? Its a red label 413 OBD1 3 series harness.
                    • BenM
                      • 2184
                      Hmm, earliest I can get up there is Saturday morning. Helping my buddy out with his car tomorrow so can't make it.
                      2012 F350 6.7PSD
                      • jahnaboi
                        • Oct 2006
                        • 1742
                        Any updates on this thread?
                        SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
                        • sharky
                          • Jan 2005
                          • 2672
                          stupid mistake on my part, I was pretty drunk when putting in a TRM chip, thought i put it in the right way but didnt, swapped chip around and then perfect.
                          • Wh33lhop
                            • 11705
                            lol. Don't think I could do that drunk. First thing I want to do after installing a chip is torture the car and make sure it works. :p
                            Edit: But I suppose you could have done an EWS delete, or just done the chip before the motor was running.
                            paint sucks
                            • M-technik-3
                              • 18946
                              Hence why booze and working on your car don't go hand and hand. I always enjoy one after I finish working.
