Cold Air Intake
  • g22
    • 274
    Cold Air Intake
    So I finally am happy with my CAI and thought I would share...
    My goal was to find something that would keep the 3 inch pipe and not mess with the ABS, cruise control or the coolant bottle. I'm not sure if I'm even going to mess with a heatshield.
    Top view
    Close up
    pulls from the stock location. I pulled the headlight to check clearance.
  • lennon
    • Jun 2008
    • 1416
    dude that is sucking nothing but hot air off of the radiator
    • g22
      • 274
      Got any suggestions? What are you running?
      • e30trooper
        • 11576
        heatsheild and you want a ram /cold air so , make a stack out of the high beam.
        • lennon
          • Jun 2008
          • 1416
          i wasnt trying to be a dick. im not running anything cause my s50s not in my car yet. i will figure out something different from that though. it may be easier for me as my condenser is gone and thats where my radiator sits.
          • g22
            • 274
            What do you mean make a stack our of the high beam? Just take out the light? What about water into the filter? I'm open to ideas
              • 34839
              you need a shield, that's a hot air intake right now. don't worry about the high beam delete, maybe for track use but it's pointless on the street. also it doesn't create a ram effect, just cooler air.
              • jahnaboi
                • Oct 2006
                • 1742
                You could make one like this.
                Isn't really that hard to do. Plus, it holds the air filter and maf in position without zip ties or bolting.
                SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
                • e30trooper
                  • 11576
                  dosnt the coolant res get hot?
                  • jahnaboi
                    • Oct 2006
                    • 1742
                    Not really. Its plastic so it retains heat pretty well. If yours is getting hot (water boiling) it could be a problem within your cooling system. The radiator and the motor itself should emit more heat than the reservoir.
                    • g22
                      • 274
                      Looks good! What type of plastic is that and where do you get it?
                      • e30trooper
                        • 11576
                        mine dosnt get hot. plus mines on the other side of the eng bay next to the coil
