Help me diagnose, videos
  • Lof8
    • Oct 2006
    • 2827
    sometimes it idles fine, others it bounces all around. I will clean the icv soon. that is not my main problem.
    I have spliced a number of videos into one to show how its cutting out hard at about 3.5 or 4k rpms. It will not accept full throttle - only up to about 3/4. It generally runs shitty and stalls a lot.
    Help me out.
    Thanks
    I got a 1222 code today as well - oxygen sensor control (o2 sensor is brand new)
    S50'd
    Originally posted by TDE30
    What is this faggy shit I have happened upon?
    I can always live in a M3. Can't M3 a house.
  • e30s52
    • Oct 2007
    • 5235
    Seems to me that it is the ICV is having some sort of vac leak.
    www.gutenparts.com
    • Lof8
      • Oct 2006
      • 2827
      The video doesn't do a super job of showing it, but the car is hitting a brick wall at about 4k rpms - just cuts out.
      Also doesn't respond to wot at all.
      Then near the end of the video, you see it will idle fine.
      S50'd
      • e30s52
        • Oct 2007
        • 5235
        The reason why I said it might be the ICV is because I had a vac leak and it was causing the same problem.
        www.gutenparts.com
        • e30trooper
          • 11576
          DB look clean on you car
          • Yage30
            • 70
            So, I've looked at some different charts on OBD1 error codes, and I've gotten conflicting results between code 1222 and code 1221.
            Some say 1222 is the O2 sensor circuit, and some say the code is thrown when the DME detects an improper fuel/air mixture ratio for more than ten seconds, which can be caused by low fuel pressure in the rail, an air leak past the MAF, etc. etc.
            I've also heard that running an exhaust without a cat will throw the code for the O2 sensor circuit as well.
            Just throwing my 2 cents in.
            Originally posted by Bene
            my eta is making a kind of high pitched bird-like sound, like a bunch of retarded cockatiels nesting in the intake manifold.
            • KU Roo
              • Oct 2009
              • 23
              It sounds to me like you have a fuel starvation problem. ICV only takes care of the idle, I don't think that's the problem. Your bigger issue is that the car hits a wall at 3.5k - 4.0k. I had a similar issue back when I had the M20 still in the car.
              Get a fuel pressure gauge, some hose, and a "T" fitting then put the guage "in-line" on the fuel line (delivery side, not return line). Check the bentley for the correct pressure at idle, then rev the engine while in neutral. You should see the pressure spike briefly as you rev the engine. The pressure regulator should do it's job and bring the pressure back down quickly. If you don't see the pressure rise when you rev the engine, the pump is weak. Of course a clogged fuel filter would cause similar problems. Good luck.
              Andrew
              • 325issguy
                • Dec 2005
                • 261
                +1 on huge vaccume leak on the icv or something. My car idled the exact same and even worse when I had the hose on the icv fall off.
                • gregslow318i
                  • Sep 2007
                  • 1918
                  vac leak, bad maf or a fuel problem. is the maf in the right direction?
                  looking for a e30m50 swap harness adapter pm me $150 shipped
                  email nitroman12@gmail.com
                  • lennon
                    • Jun 2008
                    • 1416
                    i agree with these guys, its gotta be a big vacuum leak or fuel starvation. perhaps a hose is routed incorrectly or disconnected and you havent noticed? have you checked fuel pressure? has it run this way since you got in running? good luck man i hope you figure it out soon. mines still not even in the car but is now a 3.2 liter hahaha. these swaps...
                    • Lof8
                      • Oct 2006
                      • 2827
                      Well, I've been all over the intake side looking for a vacuum leak with no finds. There really aren't many sources for a leak. I replaced the icv to intake mani clip with slight improvement.
                      My next try will be a crank positions sensor - I've read about some similar symptoms for this.
                      I'm also a little concerned my catalytic converter may have clogged up - I'll look into this further if a cps does nothing.
                      There was one day where it ran decent (not perfect). Its been like this ever since.
                      Thanks for the help guys.
                      S50'd
                      • gregslow318i
                        • Sep 2007
                        • 1918
                        dont bother with the cps if it was bad the car would not run, does you fuel rail have a fpr on it? is the maf installed correctly with the arrow pointing in the direction of air flow?
                        • Lof8
                          • Oct 2006
                          • 2827
                          Thats what I thought too, but Jordan has a thread on bimmerforums with the same symptoms - his prob was a cps. He also thought the cps was all or nothing.
                          rail has the factory fpr on it.
                          Arrow is pointing direction of airflow on the maf.
                          S50'd
                          • jahnaboi
                            • Oct 2006
                            • 1742
                            Have you tried unplugging the maf and to see if the car would run better?
                            Also, could it be that you are hitting the soft rev limiter?
                            SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
                            • jrdeamicis
                              • Nov 2008
                              • 956
                              That is wrong.
                              What sometimes happens with the CPS is that the signal is fine for low RPM 0-3000 but it starts to get broken up after that. Proven with an oscilloscope. Sounds EXACTLY like what happened to me. But the WOT sympton is a little different.
                              Past Car : E30 S50 6 Speed 5 Lug 3.73
                              Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                              ___________________________________________
                              BNB Designs
                              Engine Swaps, Fabrication, Innovation, General Repair
                              Richmond CA
                              Julian 848-248-8029
