Blue water temp sensor HELP please
  • BlackE30
    • Sep 2004
    • 605
    I have a dilemma here that has been an issue since I bought this car 2 years ago. I just found out somewhat recently that this issue has been messing with my DME giving it the wrong info.
    Someone previously tapped the cylinder head in both ports to a 14mm size. The blue water temp sensor for the s50 is 12 x 1.5mm and is therefore too small. My car has had a black cap sensor which I am assuming has a different resistance value than the blue one.
    Any one know where I can get an adapter so that I can utilize the correct sensor? It would be 14mm x 1.5 Male to 12mm x 1.5 female to fit the 12mm x 1.5 into the cylinder head(14mm). I haven't been able to find any.
    Thanks,
    Jeff
    • 37833
    Jeff, maybe this little gem will solve your problem?
    Grover Beach, California
    BimmerHeads.com
    • BlackE30
      • Sep 2004
      • 605
      I don't have that hose coming out of my cylinder head.
      • Jason89i
        • Sep 2004
        • 875
        time-sert
        should have a 14x1.5 to 12x1.5 somewhere.
        jason
        • sharky
          • Jan 2005
          • 2672
          so re tap the head
          • 416stroker
            • May 2008
            • 2448
            Auto-Meter should have adapters for you.
            84 318I Delphin RIP
            87 325IS delphin 24v Sold
            89 325 Alpineweiss
            • BlackE30
              • Sep 2004
              • 605
              They all go to 1/8 NPT I suppose I could tap one of those to a 12 x 1.5. As long as it didn't break.
              • 416stroker
                • May 2008
                • 2448
                I got some bigger than that I still have a few that came in the kit Ill see if one is 14x1.5
                I forget what they where on the standard side but im sure you could retap them I know its like 3/8 or something.
                If I do ill mail them to you.
                84 318I Delphin RIP
                89 325 Alpineweiss
                • BlackE30
                  • Sep 2004
                  • 605
                  Ok cool, let me know.
                  • Jason89i
                    • Sep 2004
                    • 875
                    Originally posted by Jason89i
                    time-sert
                    jason
                    no tapping necessary. time-sert makes the 14x1.5 to 12x1.5 for oil pans. google it.
                    jason
                    • BlackE30
                      • Sep 2004
                      • 605
                      jason
                      The only one I can find is for "tin" pans only. I need an aluminum one. Care to enlighten me on where you found that one?
                      Appreciate the help.
                      Jeff
                      • hoveringuy
                        • Dec 2005
                        • 2752
                        I can't help with the threads, but I can attest to how the wrong sensor will mess with your DME. I just discovered my IAT has the wrong resistance and the correct one is making a HUGE difference in how it runs!
                        • BlackE30
                          • Sep 2004
                          • 605
                          I have a kit on order from Timesert that should fix the problem. They were extremely helpful on the phone. I'll keep you guys updated on the install and how the car runs with the right sensor. It's supposed to arrive next week.
                          Thanks Jason for the tip.
                          • rcfanatic
                            • 490
                            Have you tried using a helicoil?
                            • flyboyx
                              • 8371
                              helicoils don't work that way. they won't have a coil to make a 14mm neck down to a 12mm. if the threads strip out of your 12mm hole, they will have a special drill bit, a special tap and an insert to repair the hole however.
                              Gigitty Gigitty!!!!
