basic cost?
  • spaceshuttle
    • 169
    basic cost?
    Is the lowest cost for a good s5x swap $5k or do you think it could be done with $4?
  • hugh jass
    • 2220
    are you doing the work yourself?
    ______________________
    ex-Chief Operating Officer
    Blunt Tech Industries
    West Coast and Pacific Rim
    • spaceshuttle
      • 169
      yes that was my plan
      • jrdeamicis
        • Nov 2008
        • 956
        Motor - 2k (Try and get as complete as possible)
        Gasket Set - 400
        Oil pan / pickup - 100
        Booster - 120
        Motor mounts - 50
        Random Bullshit - 500
        Other random bullshit - 500.
        Yes. But if you need to rebuild anything. Its a little more expensive.
        Past Car : E30 S50 6 Speed 5 Lug 3.73
        Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
        ___________________________________________
        BNB Designs
        Engine Swaps, Fabrication, Innovation, General Repair
        Richmond CA
        Julian 848-248-8029
        • justin_l_
          • Jun 2007
          • 1079
          Gasket Set - 400
          Booster - Move the stock booster
          Motor mounts - 50-Cheaper through RM European
          Converting to OBD 1 can get a little pricy if you dont take you time waitng for deals.
          • Mstngcobr761
            • Apr 2008
            • 557
            Depends if you get a wiring adapter or do it yourself also
            Go to local pick and pulls also I got my m50 oil pan, pickup and tube for 16.00
            • hoveringuy
              • Dec 2005
              • 2697
              It depends on how patient you are. If you need the stuff NOW you'll pay for it. If you can wait for deals you'll save a lot of money. I see stuff come up on CL occasionally that are just screaming buys.
              I got a complete, running M50 for $350 with everything, but I'd be careful not to put too much emphasis on cheap if it's not in good condition. Nothing will cost you more than a cheap S50!
              • Wh33lhop
                • 11705
                Gasket Set - 400
                Booster - 120
                Motor mounts - 50
                You can relocate the stock booster to save a bit (also I got an E32 booster and MC in good condition for $50 in a junkyard, but you'll need to do a remote brake fluid reservoir if you do that).
                But basically yeah. It depends on how much stuff you want to replace while it's out. Seals? Gaskets? T-stat and housing? Clutch? Fuel and vacuum hoses? Maybe lighten the flywheel? Definitely do the water pump unless it's been changed in the past like... week. :p I'd do everything else you can while it's out. And remember, it will always go over budget. We're talking a motor swap here, it's tough to think of everything in one sitting.
                And if you can sit around and wait, you can definitely find deals and jump on them. But when you've got the motor out of the car and are doing the swap and realize you need x and y parts you may not want to just wait and dawdle around waiting and lowballing any more. ;) If it's your first swap, you'll run into things you didn't expect.
                paint sucks
                • spaceshuttle
                  • 169
                  sounds like fun ha. I asked if i could do for $4k because I am going to sell my other car for that much but I think Ill wait and save up a little more before I start
                  • dude8383
                    • Jan 2005
                    • 10387
                    yeh you want a good buffer zone for odds and ends.
                    • MattM
                      • Apr 2009
                      • 931
                      your clutch/flywheel and exhuast system plans will really make or break the budget.
                      Full Build Thread Here
                      • MIKe30
                        • Sep 2006
                        • 2334
                        keep it obd2, and run the stock dme the motor comes with and get a $100 ews delete from TRM or any other aftermarket obd2 tuning company. Done. Couple extra bucks for rear o2 sensor, and secondary air pump delete while you're at it.
                        Never thought about this, but it's pretty on point especially when trying to keep a low budget. It's shit like this you don't think of and piles up the number figures.
