obd2 m52 swap problems.
  • 87e30
    • Jul 2008
    • 5676
    Originally posted by flyboyx
    in reading this thread(what you posted above), i don't know how you pulled your codes. if you have a peake analyzer or equivalent, i assume you would have done a fault code reset. if you did the stomp test, i don't think disconnecting the battery will necessarily reset the codes stored in your ecu. in most(if not all) cases, you need to reset the codes to make them go away. the first time i pulled my codes with a peake, i had injector #1 failure. i reset them with the analyzer, the code went away never to come back.
    Does the reset on the peak tool not actually do anything for obd2 cars?
    Was your car running like SHIT with the code on, then once reset the car ran fine?
    Very interesting.
    I just hate everyone.
    No need for discretion.
    • matt
      • 3732
      1) There is no stomp test for OBD2 cars. You have to have a peake or generic OBD2 scanner. (with a generic OBD2 port of some kind)
      2) Reseting the fault codes will only make the car run right if the only thing making the car NOT run right was a limp mode.
      3) Pulling the ECU connector will clear OBD1 codes but will not clear OBD2 codes.
      • 87e30
        • Jul 2008
        • 5676
        My check engine light doesn't work. I've been using a Peake tool, I reset once, and re-drove, and then re-pulled the codes.
        A pretty knowledgeable guy on bimmerforums told me to just pop open the ECU case, he thinks I fried it. I've kind of had this hunch since day one.
        So I'll pop open the case, if it's not fried then I'll trace the wiring.
        • matt
          • 3732
          Well, maybe that's it. The only things I've ever seen kill an ECU are water damage and connecting power backwards.
          • 87e30
            • Jul 2008
            • 5676
            Well I did hook a ground up to the power line... Is that considered backwards? I was under the impression that it was, but I'm really not sure how it all works to be quite honest.
            • MaloventEvil
              • 248
              yes. :( pull it to be sure.
              • evil_twin
                • Nov 2007
                • 2965
                Check the pins that connect to the ecu computer itself. I've seen those break before.
                Paypal: vdang5@gmail.com
                Delta Auto Care
                2875-C Towerview Road
                Herndon, VA
                703.435.1375
                My Feedback Thread: Evil_Twin
                • BlUe E30
                  • Jun 2008
                  • 180
                  cant clear OBD2 codes with the 16 pin have to go through the 20 pin
                  • 87e30
                    • Jul 2008
                    • 5676
                    The 20 pin is the large round connector, right? That's the only one I have, I do not have the smaller interior connection in my car.
                    Thanks for the help guys, I'll check over the ECU tomorrow.
                    • BlUe E30
                      • Jun 2008
                      • 180
                      yes then your fine, didnt know if somehow you put the OBD2 connector in there with the swap. good luck, if it is fried you looking for a new dme, key, and driveaway protection module?
                      • matt
                        • 3732
                        It's perfectly possible to clear and read codes through the OBD2 port. (If you wire one in properly) Otherwise what's the point?
                        • 87e30
                          • Jul 2008
                          • 5676
                          I have another ECU already. I think I will just take it and my existing EWS module into a local BMW shop that can align them - allowing a new DME to work with the current EWS. (Just like you'd do if you had a real obd2 e36)
                          Awesome. Yeah, it should be working properly based on what the guy told me when I bought the harness. I just had to cut one wire off of it and hook it up to 12v to power the code reader.
                          • BlUe E30
                            • Jun 2008
                            • 180
                            because on bmws up until the 2000's they had a 20 pin and a 16 pin the 20 pin was the one that you used to clear and read all codes, the 16 pin only allowed you to read emissions problems as mandated by the US government. if he everything from the original OBD2 keeping it OBD2 (which i didnt know if he did or not) you would have to read it through the 20 pin. and you had to cut off the park neutral saftey switch wire. and also can was on all cars not just automatics.
                            • matt
                              • 3732
                              No no no no.
                              The port in the car allows you to talk to the DME and EGS only. The one under the hood lets you talk to the other modules in the car.
                              The thing is, once you put the motor in an e30, you don't have any of those other modules to talk to. All you need is one wire connected between each daig port and the ECU, plus power and ground at each, and you can do whatever you want to the ECU.
                              BTW, EWS alignment may not work if you don't have the EWS wired in correctly/completely.
                              • etxxz
                                • Feb 2006
                                • 2085
                                his ews works because he can start up the car. what may be a problem is a dealer aligning the DME/KEY/EWSII if you don't own the car (VIN) all your stuff came from. I had the same problem so if i loose my key, im screwed. i would have to pay $200 to bimmerworld to remove the ews.. which is what the dealer would charge anyways for a key.
                                have you opened the dme already?
                                No more e30s for me.
                                88 black BMW OBDII 332is dedicated track [sold]
                                88 BMW OBDII bronzit 332is [RIP 03/08]
                                91 BMW 325i [sold]
                                86 Corolla 'Ae86' HB 20v trd [sold]
                                http://youtube.com/watch?v=pTj7Hn9v5Rs
