Yet another "what swap should I do thread", but ive searched and havent come up with much that applies to my situation.
My m20 runs well enough now, but eventually its gonna need replacement, rebuild, or otherwise. I'd like to get planning now, set up a budget and start collecting parts.
The kicker is I live in California, home of the uber tight smog regulations.
Whatever is done to my car either needs to pass smog every 2 years, or be easily reversable in a weekend. My end goals will be reliability, and an increase in power over the stock M20. Figure a budget of $4-5k all said and done.
Current options im considering:
1. Rebuild the stock M20, perhaps go NA stroker, cams, and tuning.-
Going this route seems to be the closest to compliance with smog regulations, at least on a visual basis as most work is internal. It also wont require any drivetrain modifications. But will that much internal work still allow me to pass emissions testing?
2. M50/S50 swap
I have heard of a member or two getting their m50/s50 swaps BAR approved in CA. If this is the route I go, what other than the longblock itself should I plan on obtaining/installing to make the swap pass?
3. Rebuild M20 and go turbo setup.
This will most likely net the most HP, but then I have to remove turbo, exhaust etc. every 2 years to pass. And will the car run well enough with all that removed in order to pass smog?
Any members/shops with experience in CA than can offer some direction?
2. M50/S50 swap
