What to fill my engine bay with that meets CA smog?
  • Uber E30
    • 1409
    Well i know they want to see your DME some times, so that would be a dead giveaway. Its all luck though, some places are super chill and some are crazy.
    -Alex
    • evangreen
      • Aug 2007
      • 148
      you can just smog it as a 95 3.0 obd1, then you will be using an obd1 ecu
      yeah i was spacing on the cats, and thinking about oxygen sensors. The obd1 stuff is similar to how the e30 is with a single o2 sensor at the x pipe. The ref will most likely check that and see a stock bmw cat, and move on...
      • Jean
        • 18228
        The ref looks for a specific # on the cat and checks if it's the right one for the engine.
        • george graves
          • 19997
          Jean - could you have passed/gotten your sticker with an aftermarket cat?
          Originally posted by Matt-B
          • Uber E30
            • 1409
            if its carb certified, yes
            -Alex
            • evangreen
              • Aug 2007
              • 148
              mine passed with the e30 cat, but like people have said, some refs are easy and some dicks
              • funcrew
                • Jun 2007
                • 1223
                Is smog inspection required in all counties in California these days? I last lived in the state in 1988.
                "If the sky were to fall tomorrow, the tall would die first."
                -Dr. Paul Forrester
                Do I LOOK like I need a psychological evaluation???
                • 416stroker
                  • May 2008
                  • 2448
                  No not in all counties.
                  84 318I Delphin RIP
                  87 325IS delphin 24v Sold
                  89 325 Alpineweiss
                  • 5KWattson
                    • Apr 2009
                    • 809
                    ...im not tryin to BAR mine right now just smog it, i am running odb1 with e30 cats, stock evap canister, all emissions and exhaust hooked up o2 a lil bit down stream from the mani's before the cat(s) so i dont think there will be any prob...now if i was going to the ref that would prob be a different story they are SUPER strik around here because all the dumbass honda ricers swap shit and get popped left and right
                    but the smog shop was closed today so this week i should make it in if i can get off work early
                    "God created turbo lag to give V8's a chance" Taylor D.
                    • Uber E30
                      • 1409
                      um, you know the smog shop does a visual right?
                      -Alex
                      • 5KWattson
                        • Apr 2009
                        • 809
                        umm yeah i know it passed visual it only failed due to high N0x an co from an exhaust leak on my down pipe....gargle my balls
                        • Uber E30
                          • 1409
                          Well the smog shop you took it to are idiots then... im sure they would love to do some ball gargling
                          -Alex
