engine storage question
  • MatRacer
    • 562
    I will take out of my car my s50 engine soon. I will maybee stay in the garage for a year. What should I do to keep it in good condition?
    E30 now S52
    2008 Suburban LTZ (Family and TT hauler)
    325xiT (Sold)
  • matt
    • 3732
    Take out the spark plugs and spray some WD40 into each hole.
    • MatRacer
      • 562
      WD40!? Really? It's not even greasy...
      E30 now S52
      325xiT (Sold)
      • matt
        • 3732
        You just need something to coat the cylinder walls. It's really not a big deal.
        • jahnaboi
          • Oct 2006
          • 1742
          Put it in a big ass vacuum bag and suck all the oxygen out so no oxidation occurs. =)
          SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
          • Justin B
            Sikky Nar Nar
            • Mar 2005
            • 4273
            Auto parts stores usually sell some sort of special can that is made for this. I think mine is made by stabil and is called fogging somethingeranother.
            • 7pilot
              • 475
              ^^^^This.
              The Can is black in colour, if that helps :D.
              Drain the engine oil (has acidic combustion by-products in it), fill with fresh. Run it for 2 minutes then shut off. That way the bearings won't be sitting in acidic oil, which etches the coatings.
              m
              • Adrian_Visser
                • Jun 2006
                • 2823
                fresh oil in the bottom end, fogging oil in the top end, maybe some fuel stabilizer in the fuel system so whatever is left in the fuel rail doesn't turn to varnish and clog your injectors, that is unless you are going to remove the fuel system components
                '89 Alpine S52 with goodies
                • MatRacer
                  • 562
                  Thanks a lot!
                  E30 now S52
                  325xiT (Sold)
                  • flyboyx
                    • 8371
                    what ever you do, don't use wd40. it will only inhibit corrosion when it is wet. once the oil dries out, what is left over promotes corrosion. seriously. if you want to see a good example of this, take one of your guns(assuming you have some), spray wd 40 on it and put it away under your bed or in your basement for a year and come back to see what you have.
                    Gigitty Gigitty!!!!
                    • justin_l_
                      • Jun 2007
                      • 1079
                      Have used fogging oil for storing thing throughout the winter for a long time, and vise versa when storing thing through the summer as well.
