M20 engine removal with or without tranny connected?
  • motorsports_3
    • Mar 2007
    • 1058
    I am in the process or removing my motor. It is an M20B27, I have everything either loose or off, all that is left is to remove it. My question is, in your guys opinion, what is easier, to remove the engine and tranny all together, remove and drop the tranny, or just disconnect the tranny and lift the motor out. I am stuck here.
    I ideally wanted to lift the motor and tranny out, but I heard it is not possible, or very very hard.
    Also where do you guys lift the motor from? I know the bracket in the front of the motor, but in the rear where do you connect the chain?
    TIA
  • Pudmunkie
    • 210
    Its possible all the ways you mentioned. I removed the last 2 with the trans attached. All I did was hook the chain up to the front eyelet (no leveler). With the trans attached it will pull up at a steep angle using only the front eye. You'll need to use a jack under the rear of the trans to help it over the cross-member.... Remove your radiator as well.
    • e30s52
      • Oct 2007
      • 5235
      Its easy to remove everything. You just need to tilt it alittle as you are pulling it. Very simple.
      www.gutenparts.com
      • BigSam
        • Jun 2008
        • 168
        +1 for removing connected. Much easier IMO.
        • motorsports_3
          • Mar 2007
          • 1058
          So how do you guys get the tranny to clear the rad support?
          • hoveringuy
            • Dec 2005
            • 2744
            Short chain on the hoist.
            • lennon
              • Jun 2008
              • 1416
              i wouldnt pull them out separate. i have pulled them connected without much trouble in the past. when i put my 24v motor in i will be dropping the m20/trans straight down after removing the rack/subframe/etc. i think this might be the easiest if you have the means to do so, but not worth it if you just wanna do a quick swap.
              • dashboardmonkey
                FUCK YOUR WAFFLES
                • Jun 2008
                • 6158
                i connect an end of the chain to the hole in the block above the starter other end of chain to eyelet on front of motor
                -Andy
                • e30 335i
                  • Sep 2009
                  • 70
                  Just jack the front of the car up and also tilt the motor and g/box on an engine crane. I did this removing my old m10 but then i installed my m30 g/box and all through the top no problems at all.:D
                  • motorsports_3
                    • Mar 2007
                    • 1058
                    Thanks guys, ill be trying this all tomorow.
                    I would love to drop it down, but with out a lift, being in my front yard, that makes it really hard.
                    • MattM
                      • Apr 2009
                      • 931
                      together is easiest, i went from a running car to an engineless car is a little less then 4 hours, by myself, first time pulling a car engine.
                      I put the M50 with Zf320 attached in the same way just in reverse.. it went smooth until the load leveler busted...lucky it was almost all the way in at that point..
                      and that same engine bay now...
                      Full Build Thread Here
                      • motorsports_3
                        • Mar 2007
                        • 1058
                        I got it out today. It went really smooth. I couldnt imagine taking it out seperate. Thanks guys
                        • Major
                          • Oct 2007
                          • 82
                          I wasn't spoilt for choice, so I ended up doing this:
                          Actually worked very well! :p
                          • BlUe E30
                            • Jun 2008
                            • 180
                            access to bmw special tools helps out very nice for this kind of stuff also ;)
                            • 7pilot
                              • 475
                              Easy.
                              If you jack up the rear of the car, you effectively lower the nose in relation to the suspended drive train.
                              It also works this way if you run short of front clearance during drivetrain installation.
                              m
