cast iron exhaust manifolds???
  • Red325es
    • 140
    For those who are using cast iron exhaust manifolds, are you spacing the engine up, to allow down pipe clearance? thanks-Pete
  • FredK
    • 14762
    Yes, I had to space my engine up to allow for stock E36 OBD-I downpipe clearance. I shimmed up around 1/2". Your experience may vary!
    • Red325es
      • 140
      thanks....did you run into any issues with engine to hood clearance?
      • FredK
        • 14762
        No, but I have no hood insulation either.
        • e30 blue
          • 69
          I did not shim the motor , but it is a 85 318i. Also had shop make mid pipes.
          • lifeiskaos
            • 1709
            FWIW I just test fitted OBD2 exhaust manifolds and midpipes. I believe OBD1 and OBD2 manifolds are the same dimensions. I don't know if the downpipes are the same. Anyways, the stock downpipe on the front manifold cleared everything just fine. The rear manifold dowpipe hits the passenger side footwell. No spacers/shims anywhere.
            Why did you need to shim it? What did the midpipes hit?
            • FredK
              • 14762
              Installed, there were no clearance issues with no spacers. However, once the mount settled, there was not enough room for the midpipe to clear the front subframe when it was being pulled off the studs. So, it's not an issue of interference during operation, but rather an issue of ease of removing the midpipe.
              Of course, it's not like you have to remove the midpipe that often, but I went through a few different exhaust configurations.
              • lifeiskaos
                • 1709
                Thanks for the reply. Is this with stock control arm lollipops? or treehouse?
                • FredK
                  • 14762
                  Well, with stock control arm lollipops, I ran into some interference on stock cast manifolds and the stock OBD-I downpipe (basically, from the dual tri flanges to the merge) right at the lollipops. I had to clearance them with a hammer and a torch.
                  With THR cabs, there is no interference there.
                  • 5KWattson
                    • Apr 2009
                    • 809
                    i made my own solid motor mounts that were a bit tall to begin with so i had no fitment issues...though i do have a vibration in the drive shaft prob due to excessive angle of tranz/motor
                    "God created turbo lag to give V8's a chance" Taylor D.
