Clutch Weirdness - Slave Cylinder not long enough??
  • nrubenstein
    • 3148
    So, after pulling the ZF back off to fix the 5th gear detent problem that I discovered immediately after installing it the first time, I have discovered that the slave does not appear to be long enough to disengage the clutch. Needless to say, that's not ideal.
    (And by "discovered," I mean "exploded the slave in the bellhousing." Fishing all that crap out was fun.)
    Clearly, I need to pull the transmission (again) and fish around, but does anyone have any ideas?
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
  • MattM
    • Apr 2009
    • 931
    clutch/flywheel combo?
    also are you using the ZF slave or the G260 slave? im pretty sure you NEED to use the ZF slave no matter the flywheel/clutch combo.
    Full Build Thread Here
      • 37829
      Slave needs to match the transmission.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • nrubenstein
        • 3148
        I have three ZF slaves sitting here.
        The clutch is from a '95 M3. New throwout bearing.
        The slave doesn't hit the throwout fork/pivot arm until it's just a third of an inch off of the mounting surface. I remember thinking that the slave seemed unusually easy to squeeze on - guess I know why.
        • nrubenstein
          • 3148
          Ah. I think I know what it is.
          It's got the fork out of an E46 328Ci in it. I guess I need to swap that out, given that they are different part numbers.
            • 37829
            Umm, yes. You need the fork that matches the transmission!
            Grover Beach, CA
            www.BimmerHeads.com
            • nrubenstein
              • 3148
              The transmission is out of a 328. It matches the transmission. What it doesn't match is the clutch.
