wont fit!
  • D-rock
    • 714
    wont fit!
    This sounds really silly. But my new strut brace won't fit on my car. It fits on my other stock e30 but not the 50 swapped. Could the swapped have maybe bent the frame a bit. Its only about half an inch off.
    Thanks!
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    No, the swapped could not have bent the frame.
    • Danny
      • 14217
      Jack up one side of the car.
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        I think one side must have to be jacked up already, has this car been in an accident?
        • Danny
          • 14217
          My bavauto bar fit on both my cars without jacking up either side.
          • D-rock
            • 714
            I did then the bolt fell. Just had to drop the whole strut and spring. :( its almost as it has caved in but its not far off.
            • Farbin Kaiber
              Lil' Puppet
              • 29502
              Thanks!
              Does not compute. Why did the "strut cave in" when trying to mount a bar on the top? Pictures?
              • D-rock
                • 714
                No nothing gaved in while doing it. Just seems the car has caved in over time that why it is not fitting.
                • Farbin Kaiber
                  Lil' Puppet
                  • 29502
                  Has it been crashed?
                  • D-rock
                    • 714
                    Everything looks fine under the car and carfaxs says no. But you can always pay people under the table these days... What's that be the only reason it is not fitting? Even though its only a bit off.
                    • Danny
                      • 14217
                      Sounds like yo shit is fucked den breah.
                      • Farbin Kaiber
                        Lil' Puppet
                        • 29502
                        Was your old car a cabrio?
                        • D-rock
                          • 714
                          It was a vert and this is a 2 door
                          • Farbin Kaiber
                            Lil' Puppet
                            • 29502
                            I knew it, There is your issue. The vert and sedan towers are a different measurement. You can't run a vert strut bar on anything other than another vert.
                            • D-rock
                              • 714
                              So they must have sent me the wrong strut!!! Thanks for the help!
