Post pics of your motor mount arms
  • Fusion
    • Nov 2009
    • 3659
    I would like to see your arm setups.
    Mine were made by the PO and I'm losing confidence in them so I'm thinking about having them redone. I'll take pics tomorrow.
  • SamE30e
    • Sep 2007
    • 4319
    ummm.... what?
    E36 mounts work just fine.
    1985 325e 2.8 Turbo VEMS
    • Wh33lhop
      • 11705
      Uh
      paint sucks
      • Fusion
        • Nov 2009
        • 3659
        No idea why he fabricated his own then. Will post asap.
        • e30s52
          • Oct 2007
          • 5235
          Do you have a m30?
          www.gutenparts.com
          • Fusion
            • Nov 2009
            • 3659
            Nope, m50b25.
            • 5KWattson
              • Apr 2009
              • 809
              yup e36 arm are what i used, but i made solid mounts going from the e36 arms to the sub-frame
              "God created turbo lag to give V8's a chance" Taylor D.
              • MattM
                • Apr 2009
                • 931
                yup, i would grab some e36 ones, they can be had for pennies at a wreaker.... Also what rubber mounts did he use underneath? and well we are at it, what else has been ghetto rigged?:roll:
                most wreakers wont know the term E36, so either you go to a pick and pull(which dont exist around these parts) or you go to a specialty BMW wreaker(got one of those:D) or you go through every model and year of E36 until you find one they have... lol... they usually get pretty confused at this point and wont like you very much... but thats life....
                Full Build Thread Here
                • herlsy
                  • Sep 2009
                  • 339
                  since we're on the topic of motor mounts, has anyone actually proven that there is a difference between the drivers side arm?
                  I've noticed that the earlier models (92/93 confirmed) didn't have the raise band going across it, the only other one ive seen in the yard was a 97 that DID have the band on the mount.
                  • Wh33lhop
                    • 11705
                    So what's the supposed difference?
                    paint sucks
                    • herlsy
                      • Sep 2009
                      • 339
                      Not sure really. It looks to be only an appearance difference, see the raised band that runs across the top?
                      Cross referencing the part on realoem says it should be the same part for all years.
                      • browntown
                        • Jun 2004
                        • 3524
                        probably just a different cast.
                          • 37832
                          There is no difference. That would make no sense.
                          Classic BMW Specialists
                          Grover Beach, CA
                          www.BimmerHeads.com
