What is the Fastest you've done a Swap
  • fiftytakedowns
    • 2460
    I heard of one guy doing it in 20 Hours.
    thought it would bring up some good discussion.
    So what was the fastest you did a swap, what went wrong, and how you would do it over.
    DISCUSS
    [/url]
    Team USA Wrestling 67KG
  • Wh33lhop
    • 11705
    About 3 months :p
    paint sucks
    • 1990m3
      • 1180
      another forum member and I went from an empty engine bay to driving the car in about 6 hours. Everything was already set up and ready to go though. it was plug and play
      • White325is
        • Oct 2006
        • 5947
        I did a swap within 20 hours once. You just got to make sure you have all your shit in order.
        • M-technik-3
          • 18946
          It's all down to prepping.
          • JGood
            • Jan 2004
            • 7959
            My first (and only) swap was done in 4 days, maybe 8 hours a day or so? I took my time and made stuff as I go (spacers, trans bracket, shifter, etc...)
            The car then sat for a week as my c101 connector was corroded and wasn't making connection, even though my wiring was right :(
            e30 restoration and V8 swap
            24 Hours of Lemons e30 build
              • 37833
              No reason a swap should take more than a few days of work as long as you have all of the parts.
              Grover Beach, California
              BimmerHeads.com
              • e30s52
                • Oct 2007
                • 5235
                About a year.
                www.gutenparts.com
                • 416stroker
                  • May 2008
                  • 2448
                  Took me about a month 1/2 to get all my stuff. Then about 16 hours to swap it all. But I got screwd it actualy took a few weeks to get it to fire due to a bad DME
                  84 318I Delphin RIP
                  87 325IS delphin 24v Sold
                  89 325 Alpineweiss
                  • dude8383
                    • Jan 2005
                    • 10387
                    Originally posted by e30s52
                    About a year.
                    Lol same boat, with a full rebuild and um paycheck to paycheck almost!!
                    • MR E30 325is
                      • Dec 2008
                      • 3300
                      I went from running M20 to another running M20 in the same E30 in about 10 hours.
                      My buddies engine swap is about to hit 5 months, and he isnt even close.
                      My previous build (currently E30-less)
                      http://www.r3vlimited.com/board/showthread.php?t=170390
                      A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                      • fiftytakedowns
                        • 2460
                        Im thinking with a 91 318is you hsould be able to do it really quick, motor in motor out?
                        Assuming you have all the right parts, including the wire connectors, and e21 booster pre-made.
                        and reuse the tranny and rear differential.
                        6hours is pretty impressive though...
                        After learnign about how quick it can be done, it gets more and more appealing to me, especially as my other build is taking almost a year. and I had all the parts ready to goo...
                        [/url]
                        • xwill112x
                          • Jan 2009
                          • 4236
                          i know a guy around here, he did a running m20, to running m50 in 12 hours.
                          • Stu
                            • 4083
                            True, M42's come out in a snap, my brother and I removed a wrecked M42 and installed a good one in less than 3 hours. The trans bolts are easy access.
                            As for how quickly you can do a 24v swap, it's all about planning like mentioned above, especially in the way of vacuum/fuel delivery and accessories. Bolting up a longblock and driveline is the easy part.
                            • fiftytakedowns
                              • 2460
                              What would you consider the hardpart then?
                              Assuming you have a pre-bought Wiring harness adapter....
                              [/url]
