What does a tuner do?
  • funcrew
    • Jun 2007
    • 1223
    When you pay a tuner to work on your engine, what exactly does he do?
    The reason I ask is that my S52/OBD1 failed smog due to running rich. It is running on a TRM chip for an S50. I'm looking for solutions to get the AFR where it needs to be.
    If custom tuning is what I need, how would I find somebody who is worth the cost to get it done?
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
  • gstuning
    • 833
    Reputation goes a long way.
    But the reason your car failed emissions is almost 100% not a tuners fault as he does not mess with that region in your ecu. You should look for generic faults with the engine.
    Gunni
    @ Prodrive / Aston Martin Racing
    • hoveringuy
      • Dec 2005
      • 2742
      I've been working with TRM for the last year trying to get my M54 tune nailed-down. One thing I can say is that no matter where the tune is, the ECU will ALWAYS adapt to 14.7 (unless WOT, open-loop when cold or sometimes idle)
      The problem is not your tune.
