5bar aftermarket FPR?
    Sorry guys, when I was searching and commented on this thread I neglected to notice which sub-category it was in. I have no opinion or experience on s54 motors.
      Originally posted by nando View Post
      I'd just use the S54 FPR in the location it's meant for (right next to the frame rail). You can get a basically brand new, "used" S54 FPR with a filter for under $50 on ebay. you can get the rest of the hardware for mounting it on the frame rail from BMW (I'd use all stock E46 M3 stuff). summitracing.com has the cheapest S54 consumables I can find - good quality stuff, too. their fuel filter is $26.50. NGK plugs are "cheap" at $9.83 a peice. lol :)
      nice thing about the S54 FPR is it has a built in schraeder valve that you can tap into for a digital FP gauge. I'd like to be able to datalog FP (I have an pressure gauge now but it's not useful while driving the car).
      yes. FP is importante!!!
      one fear of mine is a decrease of pressure in the line to rail if FPR is mounted remote - but as long as pressure is constant during running it should be tunable
        This was my concern. I tried (currently installing) to preserve the stock fuel line coming off the engine. Because of this, you are very limited in where you can put the fuel filter/fpr assembly. My thinking now is to break the two apart as I said before, mount the FPR to the stock S54 line and run about 2' of fuel line to the filter mounted in the transmission tunnel. I removed the fitting at the end of the fuel filter last night and it is a 12mm fitting. My only issue now is the hose barb I have to connect to the 12mm fitting is 3/8, while the rest is ~5/16. Not much of a difference, but different.
          email Alex at ABL he has the fitting for this game
          Sent from my iPhone using Tapatalk - now Free
