Bypassing EWS
  • dirtysix
    • 806
    Your best bet is to wait and watch what Josh/Hybrid on BS does with his S50b32 swap.
    If your nice to him he might hold your hand through it (he'll do it anyway cause he's that kinda guy).
    • ethrty
      • Nov 2009
      • 342
      ^^ S50 wont have EWS though will it? at least not the same version as my car :S
      • Eric
        • 5138
        my S50B30 does
        • dirtysix
          • 806
          The S50b32, you know, from the Evo M3/ZM3???
          Runs the same systems as the 328.
          • ethrty
            • Nov 2009
            • 342
            I have no experience and no research on S engines to be honest! go easy on me :D
            • M3 euro ltw
              Site Sponsor
              • 259
              RE: S50B32 vs B30
              All the S50B32 engines had EWS of some sort. The MZ3's often had EWS III.
              The last of the S50B30's had it too.
              No, to an obove poster, you can not do aftermarket keys. Please re-read my post, there are 10 unique keys made, 4 handed to the buyer of the car, 6 on hold in the factory to be offered as replacements. If you were to use up all 10 keys, you'd have a problem, and actually need a new set of cylinders for all the locks and ignition column, as well as EWS set etc...
              Trying to make the world a better place, 6 TB at a time.
              http://abloriginalparts.com/
              • DanThe
                • Mar 2006
                • 98
                Nearly, the EWS module is produced with 10 matching chips, the chips are stored and fitted to keys when requested, if you use all the 10 chips you have to buy a new EWS module with chips and have it aligned to the engine ECU. Locks dont need touching.
                The early S50B30 engines didnt have EWS as the M3 was available from 1993, EWS came in 95.
                As has been stated the start signal is not a common type, it is a pulsing type pattern that changes every time the key is read by the module, even if you replicated the pattern you wouldnt be able to use it as once power is cut the pattern changes
                • Eric
                  • 5138
                  SOOOOOOO....
                  What ECU can I swap my silver label 075 with to get non EWS on my euro S50B30?
                  • M3 euro ltw
                    Site Sponsor
                    • 259
                    Thanks!
                    Hey thanks! I appreciate the correction...I had assumed that the chips were in keys already, and that you were fubar if you used them up.... good to know. I was told by the dealer that you could only order certain numbers of the different key types, so I assumed that they chips were loaded in pre-made keys. Sounds like you know more on that subject than I thought I did!
                    You are of course also correct on the rolling codes...since that is not the primary issue with alignment, I usually don't get into that on forums....
                    • Iain
                      • Oct 2005
                      • 2815
                      Am I crazy in suggesting an aftermarket ECU? Expensive, yes, but saves these hassles...
                      Pork Hunt Motorsport
                      eBay is like the summit racing catalog for today's special Olympics crowd
                      • dirtysix
                        • 806
                        Yup. You are with this budget mate.
                        • M3 euro ltw
                          Site Sponsor
                          • 259
                          RE: Aftermarket ECU for S50B32
                          I don't think you're crazy....
                          Dedicated to Euro motors, S54 transplants , S54 swaps, electric power steering and other BMW and DTA tuning projects including drive by wire delete
                          But then again I'm biased...
                          OK... to be up front, the EWS issues alone are probably not worth going to an aftermarket ECU, we're all just showing off our acculated knowledge.....we like to pontificate and show off, makes us feel important.
                          However, on the S50B32 it may not be as expensive as you think...
                          • Eric
                            • 5138
                            how much?
