who tracks their swapped car?.....
  • JRKOUPE
    • Dec 2004
    • 3159
    Originally posted by briham89
    yes it is noticable on left hand turns. Get a VAC baffle.
    can you elaborate?......
    do you run a gauge?......what is normal press?......what does it drop to?....
    • JRKOUPE
      • Dec 2004
      • 3159
      Originally posted by shiboujin
      I track my turbo M50. Had some overheating issues and I get lifter tick now and then, but nothing too bad.
      I assume no gauge?...
      • JRKOUPE
        • Dec 2004
        • 3159
        Originally posted by Dominic49
        i have drifted on my mine for the past year now no real issues just lots of r3vlimit
        no real issues?.......any fake issues?.....
        • JRKOUPE
          • Dec 2004
          • 3159
          Originally posted by gobuffs
          Euro motor, track only since I built the car. Race car now. No oiling issues ever. Regular E36 oil pump, E34 pan. Oil sprocket tack welded on. No problems ever. Data log to prove it. I don't even have an accusump on it. There are other people that have had huge issues with oiling. *shrug* Mine is just a data point. Proves nothing.
          does the euro have any differing oiling upgrades?...
          " just a data point?".....what does that mean?...
          blows me away.....how can some have huge isssues...other's not?...
          • e30polak
            • 6136
            The Euro motor, as well as the s54 have different oil filter housings, which hook up to an oil cooler.
            INSTAGRAM: @UNDR8D_EMPIRE
            • lennon
              • Jun 2008
              • 1416
              well he said he is running the e34 pan setup like the non-euro 24v cars, and isnt the pan and pickup the issue in question?
              also, i believe he means he is just a data point, just one case, that doesnt mean all 24v motors will be the same.
              but i should let him speak for himself...
              • JRKOUPE
                • Dec 2004
                • 3159
                I understand better now...thanks.
                • gobuffs
                  • Dec 2004
                  • 513
                  that pretty much covers it. Thanks.
                  The only other thing I can add is, during my research all 6 cylinder E36s use the same pump except the Euro 3.2. Even the Euro 3L uses the same pump as the 2.0L I6.
                  • FredK
                    • 14761
                    On a Euro/S54 swap, does the oil pump gear get changed to the standard E36 pump gear? What about the oil pump chain?
                    • markseven
                      • Sep 2006
                      • 5327
                      Originally posted by M-technik-3
                      Yes with no Oil Pressure gauge, just added a quart more oil for track days. Drained the oil out when I got home some days others I did not.
                      Plenty of people do that, but I wonder about the negative effects of overfilling the crank case.
                      I Timothy 2:1-2
                      • kishg
                        • Sep 2006
                        • 2624
                        no issues with quart over.. baffle can't hurt can it ?
                        '12 F30 328i Sport Line
                        '91 SpecE30 #523
                        '00 Ford F-350 Dually Tow Vehicle
                        BMWCCA #360858 NASA #
                        128290
                        • gobuffs
                          • Dec 2004
                          • 513
                          Chain stays, gear changes.
                          • e30s50dan
                            • Nov 2008
                            • 2076
                            big believer of oil baffles too..have them on the 944 track car,now the oil light doesnt even flicker when making sharp left turns...will be on my 88' M50/M52 track car
                            NASA
                            BMWCCA member
                            PCA member 25yrs
                            1991 318IS slick top
                            1997 M3 sedan
                            2001 325CI DD
                            “whoever turns the wheel the least, wins"
                            • daleb
                              • Mar 2004
                              • 28
                              gobuffs: which tracks do you race on? Are you right hand tracks or left hand tracks?
                              I've been racing an M20 in the pacific NW for the last 9 years, long left sweepers when using the stock oil pan, no baffle, caused OP to drop into the 20psi range for a few seconds, then it would recover. I ran it like that for years.
                              Others racing M20s in the Pacific NW would race for years at Pacific Raceways, Portland Intl Raceway, Spokane Race, Mission Raceway(BC), no trouble.
                              One trip to Thunder Hill in CA, and the next race, their bottom end goes boom.
                              As a group (ICSCC) we stopped racing Thunder Hill a few years ago.
                              Pacific Raceways is left hand, Portland Intl Raceway is right hand, Thunder Hill is a little bit of everything.
                              92 325ic (owned 2008-2016)
                              • JRKOUPE
                                • Dec 2004
                                • 3159
                                you have a swapped car?........more secrets?.....
