S52 from a 98 M3
obdI from 94 325is
stock computer from early 95 M3, no aftermarket chip (pre ews)
It drives great when I'm taking it easy. When i get on it hard it just cuts out when i shift or clutch kick. Its feels like it just turns off, but obviously it doesn't. Then it almost immediately gets going again.
I am using stock 94 325is injectors with a 95 m3 computer. Do you guys think it is the injectors. I also have 98 M3 injectors but they aren't installed. Should i buy s50 injectors? or is the problem possibly from something unrelated to the injectors.
Also the cars seems to be limited at 120? same issue, or is does the computer think im going a different speed then i am really going. I have a 98 m3 trans and a 3.73 diff.
thanks all.
obdI from 94 325is
thanks all.
