Today while installing my iX booster I found that I had been missing info. Aftter doing some reasearch I found there are two options. Someone correct me if these are incorrect.
Option 1. Use booster with stock spacer. This would require a different booster, and remote res.
Option 2. Do not use spacer, and bolt booster directly to firewall. This would require you to drill new holes, the booster only has two, and they are closer. It would also require you to shorten the rod that connects to the pedal.
Are those two options correct?
