Reinforce chassis
  • damith
    • 422
    Reinforce chassis
    Does any of you reinforce your chassis/ subframe when you do m5x / s5x swaps into e30?
    [All the Bronzit haters]
  • balooshinakus
    • 511
    Nope
    • loonibab325i
      • Dec 2005
      • 770
      sometimes it feels like it :-O
      but yeah.. no
      s52 0-150mph & more http://www.youtube.com/loonibab325i
      • FredK
        • 14759
        At the very least, reinforce the front subframe with Turner's weld-in kit, or AKG's weld-in kit. It's a very convenient time to weld. I'd weld on AKG's front swaybar reinforcement plates as well.
        • 7pilot
          • 475
          From personal experience, the original S14 engine that I use in the car off track season ripped a piece out of the subframe.
          The S52 would do the same even more quickly.
          m
          • M-technik-3
            • 18946
            m
            S14 is due to vibrations created by big non counter weighted 4 cylinder. Six is more balanced engine and does not create the same harmonics as the S14.
            • sharky
              • Jan 2005
              • 2672
              I did the turner reinforcements in the front ( the large triangle piece needs to be ground to a more open hole due to the orientation on the swap motor mounts) I also did rear trailing arm reinforcement and sway bar mount reinforcement.
              • damith
                • 422
                Thanks you all for the answers.
                Is it possible for you to take few pics and share it here? appriciated :)
                • rThor432
                  • Feb 2007
                  • 3907
                  If you look in this thread about half way down you can see the Turner weld-in kit process for the front subframe--
                  I've also got the rear swaybar link reinforcements, wishbone arm reinforcements, and the rear camber/toe adjustment setup welded in. I drove my S52 car for a bit over a year and didn't blow anything up. Actually, there were no signs of extreme stess anywhere on the subframes, or chassis for that matter.
                  Edit: 3k post
                  • damith
                    • 422
                    Edit: 3k post
                    dang.. how did I miss that post. Thanks a million.
                    • z31maniac
                      • 17566
                      Yup, I've also got a front subframe that's been reinforced with the TMS kit, then blasted and powdercoated for sale.
                      www.gutenparts.com
                      • 7pilot
                        • 475
                        There is torque and the reaction to torque that alternately pushes down then pulls up on the RS engine mount.
                        Big ol' leverage moment at that spot.
                        m
