has anyone use the 318is trans (240) on a 24v swap & what driveshaft, flywheels & starter do I use. Im fresh to this 24v swap thing Im switching back from high hp vw cause the drag racing is costing too much...
im using the getrag240 with my 24v swap. That being said, anyone who puts a getrag240 on anything more than an m50 must like being under their car alot, or likes pulling the motor again to replace the trans.
Correct me if I am wrong but looking at realoem.com diagrams for both the ZF and getrag 260 mounting there are 5 bolts used not 8.
Obviously the 260 will be tilted 15 degrees where as the 240 will sit straight. I have heard of some people having the bottom bolt hole not line up. However I have never heard of there being leftover boltholes is this true?
Reason: One big run on sentance
I never had to pull the motor to do any clutches on 24v engines...
if you can find one, use the selector rod from a 320i manual. the 320 runs a G240 gearbox with a G260 bellhousing, read 6cylinder + G240, same as M5x. Proof: thats what im using and requires no modification
wicked - I had the same question.
running: NV M50 - g240 - manual e36 ds w/e30 csb - keeping the 4.10 open for the moment.
edit: op - I used an m20 (e30 325i) single mass flywheel and had it lightened a little - and of course you need the m20 starter.
