getrag 240 trans
  • ethrty
    • Nov 2009
    • 342
    yeah. youll probably find this solution isnt an overly common one because the US didnt get the 320i so people who experiement dont have parts such as that to use. But you should find importing a linkage from the states reletively easy, and the better option than lengthening a 325i linkage or shortning a 318i linkage
    • ScHpAnKy
      • 1573
      Originally posted by 1mz
      wicked - I had the same question.
      running: NV M50 - g240 - manual e36 ds w/e30 csb - keeping the 4.10 open for the moment.
      edit: op - I used an m20 (e30 325i) single mass flywheel and had it lightened a little - and of course you need the m20 starter.
      I thought the NV M50 starter was the same as the m20, do you have a pic of it by any chance?
      91 318i | 87 535iS
      • 1mz
        • Jan 2009
        • 641
        funny story - when I posted that, I went later on in the day to try and hook up my starter. I discovered I have 3 of them. 2 of which both have the same hole in the top center of the half circle shape cone that sticks over the starter gear for the plug that sticks off the bellhousing. It seems that neither of those fit onto that plug, and the 3rd one, which also looks the oldest - only has 2 holes for the bolts that secure it to the bellhousing, no hole for the plug in the middle. SO i actually have no idea which is which and which one works, so I'll be posting pictures probably by Wednesday to try and solve this mystery
        http://l0st0n3.mybrute.com
        http://l0st-0n3.mybrute.com
        Work in progress: 1991 318i m50 swap
        Feedback thread :up:
        I prefer having a female in the car at all times. They generally smell good, but you do have to put up with that hole in their face.
        • xwill112x
          • Jan 2009
          • 4236
          so will the m50 starter work with a dual mass getrag 240 flywheel?
          • ethrty
            • Nov 2009
            • 342
            possibly. but your primary issue there is if the flywheel will work. if a stock M20 flywheel (single mass) wont work without being shaved, i fail to see how a dual mass will.
            • xwill112x
              • Jan 2009
              • 4236
              are you sure?? ive been told the flywheel will work?
              if not using the stock flywheel, what would be the ideal choice for the g240?
              • ethrty
                • Nov 2009
                • 342
                have not heard of anyone pulling it off. put it that way. i am using a shaved M20 flywheel (not sure on weight, but the back is shaved to the ring gear, just over half stock weight probably) and M20 clutch/pressure plate. Car isnt running yet so cant offer personal experience on how it is to drive. have an M40 dual mass here which i believe is the same as M42 but that thing priobablyweighs more than the gearbox itself.
                if you are going to run the M4x dualmass you will need to shave the fly to the ring gear on the back anyway because of clearance issues, which is probably why most people just buy an M20 fly and shave the bitch
