Sharing is caring
  • xLegendOZWest
    • Jan 2009
    • 406
    Sharing is caring
    just finished up my adapter and id like to share it with my fellow r3vans (r3vers? r3vtuckians? ) the car is a 1988 325IC. the engine is a non VANOS M50-B25.
    E36 harness with all the auto gook removed. the e 36 ETM was vastly hard to follow but AKGs chart seemed to match what i found very well.
    E30 (body side) pin #/ga (in mm)/color--------e36 (engine side) pin#
    1/.75.BLUE (ALT frm D+ on alt)-------------------- Alternator charging 25
    2/.5/BU/BK OIL STATIC.----------------------------NA
    3 NOTHING-----------------------------------------NA
    4/.5/BR/VIO G- FOR H2O TEMP----------------------12
    5/.5/BK BRN OIL PRESURE SWITCH.-------------------23
    6/.75/GRN/WHT(OR YL) O2 HEATER RELAY------- NOT USED.
    7/1.5/GRN USED AS REMOTE WIRE TO DME (non fused) -------------21
    8 .5 /YL/WT ECONO GAUGE.------------------------------------24
    9 .5 BLK TACH FROM DME TO CLUSTER.--------------------------20
    10/.5/VI/GN OIL LEVEL DYNAMIC.-----------------------------NA
    11 .75/WT GN DIAG.---------------------------------------19
    12 BRN/BLK CEL------------------------------------------8
    13 2.5/ VIO/RED TO FUEL PUMP.-----------------------------13
    14 .5/BU/YL VSS TO MOTRONIC (USED?)-----------------------14
    15/.75 BK GRN K5/K7 UNLOADER. G- TO STARTER.-------------15
    16/.5/ WT/BK DIAG. NO CON.------------------------------NA
    17 NOTHING--------------------------------------------NA
    18 2.5 BK/YL STARTER----------------------------------18
    20/.75/BR COOLANT TEMP SEND/ ABS?? (power from main relay..)11
    hope it helps some of you. feel free to correct me if anything seems outta place.
    Live Fast. Drive Faster.
    "Nitrous is like a hot girl with an STD... :)
    You wanna hit it, but your afraid of the consequences :(
  • MattM
    • Apr 2009
    • 931
    have you run the engine yet? i know the akg had afew errors for my NV M50, why did you leave out the static oil sensor?
    Full Build Thread Here
