high rpm bog?
  • rThor432
    • Feb 2007
    • 3907
    Originally posted by hendrixvodu
    anyone know what i wire it to?
    You can wire it into several spots. The easiest are the cruise control pick-up (green plug that plugs into speedo) or the OBC. Both of those see the speed signal.
    • hendrixvodu
      • Jan 2007
      • 2514
      wellllllllllll....the car did come with cruise and it has no obc hahha its a base 318 no power windows, cruise, obc, check panel, ect hahah so anywhere else i can try?
      -His-
      87 e30 325i
      87 e24 m6
      05 e83 x3
      94 e32 740i 5spd
      -Hers-
      89 e30 325i
      18 f48 x1
      • rThor432
        • Feb 2007
        • 3907
        You can still tap into where the cruise is normally mounted on the cluster. You can pick up the green plug from the boneyard and then just wire into that. My car didn't have cruise or the OBC, but I did use the green plug to pick up the signal.
